Super Wide Body R34 Rolling Shell
ENR34 GT4
RB25DE
Attesa (GTR 4WD system)
Same gearbox
Not Complied
The motor and gearbox would have low KM's from sitting there.
Has been sitting for 10+ years easily
One of those projects that you run out of time for
Comes as you see it, has a lot of parts on the inside
Not all there.
Rear Windscreen is just floating atm, rear quarter glasses are included.
Dash and some plastics
I may have part or both pieces of the rear seats.
What you see is what you'll get.
$2750
Pick up Capalaba, Brisbane.
  • 4 months later...
    • If there's a next time, next exit after mine is Costco 😛
    • OK. But what about parts of the block that, when assembled, were twisted into a position that pushed into the void space, which, when disassembled, then released that force and opened back up, thus putting the grout into tension? Would effectively just pull the cast iron off the grout at the interface, leaving a tiny void and benefitting not much at all. Swings, and roundabouts. It's like putting something tiny into the fleshlight and finding out you needed a smaller one, to perhaps follow your area of expertise.
    • Nah. You buy a kit that has shorter tubes.
    • I didnt present too many conclusions because I wanted your opinions and feedback based on your own experiences. I don't know the exact material, but it is similar to concrete and therfor only has valuable strength in compression. The forces on the set material once the head is removed would mostly be in compression since the grout wants to retain its shape and the block wants to return to its relaxed state since it's still within the elastic region. The grout would theoretically make the block more rigid. The exact amount would take a better setup on my end. Thought experiment: Instead of aliens, twist your favorite fleshlite. Now fill it with grout and allow it to sit for a week. Now try to twist it again. Observe what you see. Now get your other one and blow into it. Observe what you see. Now put it into a can and fill the space between your fleshlite and the can. After it sets blow into it. Less movement in torsion and less expansion i hope.
