Hey guys, so i was doing a few launches and then all of a sudden but clutch pedal got stuck to the floor.
After checking we saw the fork pivot fall snapped at the thread. I always heard a squeaking/creaking noise from the box when i pushed the pedal in.. maybe related? ?
I've pulled the box out and now cant get the thread out of the box housing. Will use the thread removal tool and see how that goes.
Clutch is a os-giken twin plate
But my main questions are:
1. Should i wait and order a nismo pivot thats 30% stronger or used a second hand stock one my mate gave me??
2. How should i lube the sleeve and the push out bearing as it seems preety dry.
3. Anything else worth servicing or lubing while the box is out?
4. Any tricks to put the box back in with the car on ramps and jack stands? Getting it out was half a nightmare
5. Also the slave cylinder rod is pushed out a fair bit with fluid leaking from under the rubber cover. Whats the go here?
Any help would be appericiated.. this is the biggest mechanical thing ive done haha thanks
https://www.sau.com.au/forums/topic/462615-clutch-fork-pivot-ball-snapped/
If you have broken a pivot I would be inclined to put the stronger one in. Its not surprising that the slave cylinder has popped out if your pivot has broken. Clean it up and put it back together. Check that your crank seal is not leaking. Gently jack up the front pulley until the cylinder head hits the fire wall while checking to see you don't damage anything in the process (watch the top hose). Put a jack under the gear box and make sure you have a mate to help you.
Since getting the box out and in is a big PITA, as is being stranded, I would definitely go for the Nismo pivot. Box is a bitch to get back in, you need to rotate it (IIRC to get the starter motor lump out of the way) then rotate it back so you cant bolt it up. Maybe i put something about that in my DIY...cant remember.
gktech are fine, the reality is anything stock or stronger will be fine. the issue is that you have been putting huge pressure on it for a while, if it has been squeaking it means it has been rubbing allot on the arm and will have made a groove, check to see if the next one will rub on the old groove, if the contact patch is off and rough it will just wear out, rub, squeek and eventually snap.
if it was lubricated when squeaking ti should have been fine.
Thanks for that, do you know the best type of lubricant to use? any sort of grease you find in supercheap?
Also what do i use on the sleeve and push out bearing for lubricating as it seemed almost dry?
Do i need to lubricate or put anything on the output shaft teeth?
thanks in advance
Don't put anything on the input shaft clutch splines, wire brush clean and then dry.
A light wipe of a heavy molybdenum grease for the throw out carrier.
What's the condition of the spigot bearing. Lot of work just to do that one again. A small dob of high MP grease for him.
How's the actual throw out lever. Check that it's not bent or has any signs of imminent failure.
I'd be looking real hard at it, something has been exerting large sideways loading on the pivot ball and that could mean a bent throw out lever or perhaps a really poor clutch setup.
i.e. Did the slave push rod need modification to get the twin plate to operate properly etc?
I am using a Gktech. No problem so far.
Same Here. Using A GKTech one with a gismo GMAX Twin plate. No issues.
Edited by R31 drift pig
Follow the lubricating advice here... it's spot on. ;)
So the gktech pivot ball arrived, and i put it on with some thread lock.
I did put a bit of anti seize copper grease on the sleeve for the push out bearing but not much, and some on the pivot ball.
It all looks like the photos below assembled.. if ive done anything wrong with the assembly can anyone tell me please
Hey guys so after 4 hours under the car jacking the box up and dropping the subframe a bit lower we got the output shaft in the clutch but it wont go all the way in, about 25 - 30mm away from the block. We tried wiggling and moving it up and down but nothing.
My question is being a twin plate clutch would the spline on the different plates moved somehow? as i didnt touch the clutch??
If i put it in 1st gear would it let the output shaft spin with the gearbox housing to line up with the second plate splines?
any advise would be appreciated
thanks
Sounds like its on the cusp of being in. Just prob needs a bit more wiggle jiggle. Unlikely the clutch plates have misaligned if you didn't touch them. I would try throwing a rope around the back end of the box and get someone inside the car to control the rope through the shifter hole, easier to adjust angle like that, while you are underneath trying to push it in. It will prob go in all the way when your trying the least. Make sure u have a bolt ready to go when it does. Lol.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
