"All imported vehicles with a magenta (purple) compliance plate whether from the ACT or another jurisdiction must be inspected at the Dickson Motor Vehicle Registry."
That is from the website. I think all Skylines and Silvia's have a purple plate - so no matter where you buy it, to transfer rego to your name in the ACT you would have to go to Dickson. I think we all agree here.
So the consensus is:
FMIC should be fine, even with hole cut through battery tray.
Pod should also be fine if held properly.
Boost controller will need to be hidden.
Any issues with the MCA coilovers? They aren't too low or something?
And one other point: I was thinking of having the car checked by some mechanic that can report to me. I inquired with Stateroads and they charge 290 for a report - its 6 pages and basically is a tick for satisfactory or not satisfactory for a list of things. Mainly it will point out a more major fault. Is it worth going with them or is there a better/cheaper alternative? I would like a check for the peace of mind.
I had paid for stateroads to do an inspection for me. Well worth the penny. It's a full report from paint correction to to rust to mechanical issues. I would use thees guys whenever I buy a car over $10,000+. Ease of mind and you know what you're paying for instead of calling their mechanic for a bias opinion. GL.\
I still have the report for my car - If you'd like to check it out. Give me a PM with your e-mail address and I'll send it over.
Edited by RosieR34
Have you considered asking the seller to drive the car to the Dickson pits for an inspection to see if it will pass before purchasing? I know it will be a hassle but for Sydney sellers might be worthwhile giving it a go so that you purchase knowing for sure. Might be an idea to look into an adm s15 instead as pretty much most things will be parted out that was different probably with the exception of rear window wiper and the digital climate control unit. Just a thought to save you more hassle than required.
Yeah I might ask him if he has plans to come down. Probably won't happen though.
If the car is mechanically good and history is clean then I would be willing to cop a bit of hassle. But really I am wondering why Dickson would make life so hard? It's not heavily modded.
Is hiding the boost controller really hard? And if the FMIC fails then I have to go stock? All else shouldn't be an issue I feel.
And I know the pains of not going back within their 28 days (or whatever the fk it's been reduced to now, allegedly) and having them discover things they glazed over the first time - blindingly obvious and ridiculously irrelevant things - resulting in another failure even though I fixed the issues from the first one. Kents.
Wondering what people's thoughts are on amount of boost. Stock S15 turbo (T28 ball bearing I think) running around 12-15 psi of boost. Would you get concerned about the longevity of the turbo - or is it pretty reliable? What sort of numbers do you all run (on Skylines)?
Also has anyone got a power brace fitted?
S15 stock turbos will happily run 16-17 psi but can't hold that till redline. They usually drop to around 14-15 psi in the top end. This is when your ecu is tuned otherwise 12 psi max.
In skylines most guys with aftermarket turbos run 18-20 psi. Some push them a bit more.
    • Dredgggggeeee time; I have recently finally started driving the car. It sat for so long that the fuel tank gave birth to rust sludge and blocked my lift pump sock and one of my walbro 460's and left grime, rust chunks and muck all through the surge tank and system. I decided to commit and pull the trigger on an oem r32 gtr fuel tank and Frenchys twin 460 / sender / surge tank hanger combo and all new larger lines and fittings etc, also boost doc heater hose kit / new heater core and a heap of other bits and shits like wideband sensor installed in the dump and Syltech iacv + lines and all wired and added to current tune. now having lightly driven it a couple times without issue, I can happily report on the hta3076 in its current tune. still no boost control switched on, 20psi gate springs, car makes 22psi at 3200rpm in 6th gear with 30-50% TPS from cruise at 100kmh. Going by the old graph, this means it should be making 300-325whp at the same numbers above. Very very responsive setup under true road driving loads. all that's left for the build is body loom + PDM, finish the remote aircon setup, install carbon fibre parts and go for full tune and 30psi. the 315 rear tyres are now performing like they're 195's, wheel spin in any gear at almost any rpm, whereas my previous setup hooked up in 3rd no issue, albeit Nt01's back then / RB25 5spd vs (new) old date r888r's Z34 6spd now, + obviously all the support upgrades I listed in the quoted post above. car sits at 1-3psi on cruise at 100kmh, expectations totally exceeded and I'm beyond stoked with all this so far. IMG_4848.mov
    • I've also been eyeing their rear axles for my car. I purchased seat mounts from them about 7 years ago and they were hot garbage so I've been a little wary about purchasing them. With that being said, please buy them and get back to us haha.
    • Can a moderator please move this into the right category.. I've accidently put this into racing build thread 🤦🏽‍♂️
