HI,
I have a 94 GTST. Finally getn my ass into gear and do some upgrades.
I had thought, bigger turbo, front mount etc etc.
Any other ideas of what i MUST do?
Any comments at all.
cheers
ben
wait, you can mod skylines?? why has no-one ever posted about this or made a guide about basic upgrades????
now THATS sarcasm.
hey, you do say "Any comments at all." so input is valid, no returns accepted.
https://www.sau.com.au/forums/topic/462644-r33-upgrade/#findComment-7676355
first thing you need to do is learn to use a search bar.
second, it's your car so do whatever you want. nobody can tell you what you MUST do, thats just stupid. sell it and buy a ferrari, its cheaper.
You need to know what YOU WANT before YOU can decide what to do.
https://www.sau.com.au/forums/topic/462644-r33-upgrade/#findComment-7679692
Hey buddy. Dont be discouraged. Basic mods like air filter, 3" straight pipe and better spark plugs will help. It all depends on what power you're looking for. Simple search will get you wherever you wanna go. :yes:
https://www.sau.com.au/forums/topic/462644-r33-upgrade/#findComment-7680490
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
