ive just joined this forum, thanks for making this a memorable experience,appreciate who bothered to reply without being a wanker. All I asked was opinion on must do?
To the cock snot, way to make a skyline brother welcome
Baptism of fire son, baptism of fire. But that's the way, don't take no shit lol. Anyway, there's heaps of info on here about starting mods; have a good read, make a budget and list of what you're looking at doing then come back with it and ask. You're getting smartass replies cos ppl can't be fkt answering the same q's that have the answers easily available; best to do your own research then ask more specific q's.
HI,
I have a 94 GTST. Finally getn my ass into gear and do some upgrades.
I had thought, bigger turbo, front mount etc etc.
Any other ideas of what i MUST do?
Any comments at all.
cheers
ben
Upgrade your suspension to something that's not shit, change all rubber bushings, full service, fix any leaks or other issues. Get better tyres.
Lots to do before looking at a front mount and bigger turbo.
that's proving the point...not hard at all to find that information, as you say...
also as Nizmo Man says, depends on what OP wants from said car, suspension upgrades can be a hell of a lot more worthwhile than doing power stuff and leaving handling shite.
thanks bro. all sorted, lots of rsearch, staying fairly standard, already have 3" and coil over, g2 high flow my stock turbo, leave existing afm, fmic, new gates racing timing kit (becaise it overdue).
What the best way to set up a cold air feed? also, do you know best dry pod filter?
Thanks, looks the same as what i had already put together, although im going to highflow the stock turbo through hypergear turbos in melbourne. also re-map the existing ecu <230rwkw?
Toshi does remaps on stock ecu
  • Like 1
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
