Hey guys,
As the subject suggests, just wanted to ask if you experiencing something similar. I understand its a 20+ year old car but want to know if mine is just extra tired or others have similar problem.
When doing hill runs and generally under heavy steering, taking corners and the likes, the doors start squeaking...
Any input appreciated.
Thanks
Its probably combo of two as dors are sitting bit off and clank when you go to shut them, then offcoarse theres chassis twisting bit. Rear sway bar should help? Don't have one atm....
Open a door, grab the top and bottom and try to move it up and down. If you hear a clunk or if there is any movement then you need new pins and probably hinges. If you get no movement at all then it is in the door brackets, try loosening them, repositioning [you only get a little bit of movement], and retightening. Haven't done Skyline doors before though.........but it should be similar.
  • Like 1
There's always the chance she's had repair work to the body, but……..
The coupe is a very flimsy body. Jack her up at one front corner and check how the doors open/shut. You may not be able to actually open them.
Slam a door and note the scuttle shake, only the ¼ window is holding it together.
I don't see a rear tower strut doing a lot, it takes a cage to get any stiffness in these chassis.
Thanks for your inputs guys, car has been looked over for me after the purchase and no signs of repair or previous accidents been found, not to say something may have been overlooked.
Mainly I was wondering if it was something common for the car or not...? Seems not.
Will definitely check on the door brackets etc and see if I can see where flimsiness comes from.
Cheers for all your input and suggestions. :)
My drivers door squeaks and it is irritating. As others have suggested, a slight twist in the chassis will do it as will the door having dropped slightly.
In my case the actual sqeak is the window rubbing against the rubber seal as the door is pillarless.
The door, hinges, chassis and rubber seals are 25 years old so for that age I would think it quite common.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
