12654366_10154570666309386_4141860202374
SAU Vic MotorKhana #1 2016
- ENTER HERE -
http://www.sauvic.com.au/entry/motorkhana/20160221
Its time to get the SAU Vic MotorKhanas under way for 2016.
Always a popular event, these days are perfect for new drivers to learn their car in a safe environment and gives a place for the seasoned driver to hone their skills.
Our first MotorKhana is being held at Foresite Driver Training. Not only a great venue but close to Melbourne. This is a day that family and friends can come, watch and cheer as you speed around the test courses.
Entries are limited to 30 entries and cost will be -
Members Entry Fee $85
Affiliated Car Clubs Entry Fee $105
Supp Regs: http://www.sauvic.com.au/download/motorkhana/SAUVICMotorkhanaSuppRegs_20160221.pdf
Disclaimer: http://docs.cams.com.au/CAMS%20Forms/Events/Disclaimers/General%20Disclaimer%20-%20Participant.doc
Members with have a 48hr priority window for entry. After that the event will be open to everyone.
Entries will be open this Friday (5-Feb-2016) with more info on the day coming soon.
Entries -
Martin Sullivan
Simon Henman
Luke Schulze
Stephanie Atkinson
Kurt Thompson
Jeremy Blackman
Huy Phan
Sam Lehmann
James McDermott
Alex Roman
Gregory Kruse
John Packham
Glenn Dunn
Dan Madden
Nicholas Momirovski
Tim Wenas
Andy King
JC Pook
Kane Martin
Paul Richardson
Chris Starr
Shamal Perera
Ben Johnson
Ryan Thai
Joselito Da Rocha
  • Like 1
https://www.sau.com.au/forums/topic/462657-sau-vic-motorkhana-1-2016/
Entries now open to the public! Come along and join in what is always a fun day at our MotorKhana #1.
Click the link and enter away :)
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
