Tomorrow I'm supposed to begin therapy for a woman who came a couple of weeks ago, after she'd started hearing a man's voice.
I refused therapy then because after testing, she demonstrated a severe shortage of serotonin, dopamine and noradrenalin.
It all happened after she'd shot up with a bad batch of smack in December. The voice she's been hearing is that of her dealer. Now, the dealer is accusing her of following him. Apparently he shoots up too.
She takes her psychotropic drugs ad hoc. The precursors that she received from me are being taken ad hoc as well (says an informant).
Looks like she'll be refused therapy again! The voices win.
https://www.sau.com.au/forums/topic/462685-therapy/
Literally the only thing I took away from that was that you refuse to help someone who doesn't submit to a chemical regimen first.
Please tell me there was more of a point Terry. I may be a difficult prick here, but I'm not really sure what your message is.
  • Like 1
https://www.sau.com.au/forums/topic/462685-therapy/#findComment-7677035
And the situation gets worse...
Last month I couldn't intervene with someone wanting to get off speed.
His doctor said he'd been born with tremors and that his Dad had used acid and his Mom, hydroponic weed.
Genes.
Good time for me to retire, but...
https://www.sau.com.au/forums/topic/462685-therapy/#findComment-7677058
Therapy won't work until brain neurotransmitters are up to speed.
I don't prescribe drugs.
I prescribe (from test results), precursor nutrients that feed the neurotransmitters.
For example...
* Tryptophan + Vit B3 > 5HTP > Serotonin
* Phenylalanine > Phenylethylamine
* Tyrosine > Noradrenalin and Dopamine
* Taurine + Glutamine + B12 > GABA
  • Like 1
https://www.sau.com.au/forums/topic/462685-therapy/#findComment-7677075
Ok terry, I apologise for jumping the gun on that one. I don't quite agree on your theories though I won't dent their potential, I just don't quite agree with the insistent direct correlation between depression and neurotransmitter imbalances. I know from unfortunate experience that temporary depletion can cause a drop in mood, however I don't think this is necessarily the underlying issue for everyone.
For what it's worth though, have a look into supplementation of 5-HTP in conjunction with EGCG - a compound in green tea that apparently inhibits an enzyme responsible for metabolism of 5-HTP, allowing it more chance to successfully cross the BBB for possible conversion to serotonin.
Edited by Trozzle
https://www.sau.com.au/forums/topic/462685-therapy/#findComment-7677170
I mainly check on ancestry lines of brain neurotransmitter deficiencies.
I presented a paper on this at Melb. Uni. in August '86.
The alarming revelation that has surfaced in the past 18 yrs though is the evidence of neurotransmitter deficiencies in people without ancestry aberrations except only for the Mum and/or Dad who'd used certain illicit drugs.
Alcohol usage also exacerbates the problems even if it doesn't necessarily cause them.
https://www.sau.com.au/forums/topic/462685-therapy/#findComment-7677184
Bear in mind things like lead poisoning and potential genetic damage that may have caused (on top of the already evident aggressive behavioural disorders). Things our parents were exposed to besides their choice use of recreational drugs, like Glyphosate (Monsanto's Roundup), BPA and any other xenoestrogens/similar hormonal 'analogues' be they synthetic or plant derived (not likely the latter).
I must stress on your own point of certain illicit drugs. I disagree with the way you place any and all recreational/illicit drugs into the same harmful group as though LSD is somehow in any way as bad as a-PVP (Flakka). I feel that those views are primarily based on anecdotal experience, which I understand carries a lot of weight behind it for many individuals myself included, which is why I offer anecdotal experience to the contrary in that my parents both used recreational drugs prior to my conception - primarily cannabis (not whilst pregnant, of course), with the occasional psychedelic. I'm fine. My partner's parents were actually very very much the same. She's fine.
So I know that's not of any value so far as conclusive evidence goes, but I'm sure you understand it influences my beliefs on that subject.
Anyway, ultimately I'm glad to have learned your actual approach to these issues. Whilst I still may not agree with your deductions and underlying causes, it's good to see you don't just throw psychotropics at patients until they have no emotions anyway. IMO, the rampant prescription of SSRI/SNRI's is abhorrent.
https://www.sau.com.au/forums/topic/462685-therapy/#findComment-7677372
Troy your comment "that my parents both used recreational drugs prior to my conception - primarily cannabis (not whilst pregnant, of course)," is interesting. Common sense as you allude to here, would suggest to not consume drugs whilst pregnant. However throughout my career I have seen approximately 100 children who have been negatively affected by their parents consuming drugs whilst pregnant...very sad.
  • Like 1
https://www.sau.com.au/forums/topic/462685-therapy/#findComment-7678100
Honestly not sure what you're saying (with regards to what I said)....but yes I can only imagine you'd have exposure to the results of drug use whilst pregnant through your work :(
https://www.sau.com.au/forums/topic/462685-therapy/#findComment-7678156
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
    • Here is picture of the rear brackets again seeming to have eating itself or corrode or whatever. Can’t describe it , hope someone could explain this
    • No i am in the uk so maybe road salt etc but checked rear and same story where handbrake cable seems to have eaten part of the bracket. Have emailed alpha omega waiting for reply
    • I've not looked at a GTR without the booster there. Is the hole and mount on the firewall not just the same as GTSt? I would have expected it to be. Nissan don't change panel stampings if they don't have to, and you'd think they'd just order/design the booster to mount to the same place.
    • They have all sorts of "failure" modes. When they are brand new, the can either be very very tight, or reasonably mobile. If they are reasonably mobile, you'll probably have a good start. If they are very tight, then they can catch/grab at every little motion, and they mark the ball or the outer race, tearing off whatever teflon lining is in the outer race, then they can rapidly degenerate from there. If they get wet, they can just rust. They are just steel and will turn red pretty quickly. Water can get in behind them and sit and cause them to become crunchy and then proceed to tear themselves up, as above. Same with grit and dirt. Manufacturers and OEMs of the arms that use them will tell you that because they are teflon lined (well, the good ones, anyway), you shouldn't grease them. If you do grease them, then the grease will catch any passing grit and dirt and hold it in place where it can cause damage. Race teams that have them will lubricate them thoroughly. They will also inspect them every 5 minutes and replace them every 10 minutes, if need be. Some manufacturers of arms will provide dust boots. These can help, but they are seldom perfect, and sometime just make the situation worse, being a place where crap can collect. I have made nappies for some of mine with PVC sheet and race tape, to try to minimise the access of crap. When they wear, you can get a tiny tiny amount of movement between the ball and the outer race. This will make clicking noises. It will also make the arm have "slop" in that the tiny amount of movement available at the inner end of an arm can cause a lot of movement out at the outer end. 0.05mm at 5mm from the pivot becomes 4mm 400mm away from the pivot. If they are too tight and binding, they impede the proper motion of the suspension arm and put loads into it and the rest of the suspension that are not supposed to be there, and can cause failure. Think broken welds, broken threaded sections on the adjustable parts, mounts ripped off the chassis, etc. All of these are possible, which is the main reason why they are essentially illegal on the road in Australia.
