Hello, i've recently done a turbo brake conversion on an n/a, all seals replaced and caliper bores and pistons cleaned before installation. but when i took the first drive there was a sound in the rear like fluid being forced out, upon stopping there was fluid on the outer lip of the disc and fluid all around the wheels, not enough to be dangerous but eventually. so i put it down to a faulty caliper as it had a speck or two of surface rust and replaced them with better condition ones, these have the exact same problem and im so confused, im assuming its the piston leaking but im hoping its the new HEL braided lines i installed as the 34 gtt lines have a little bit of thread exposed from the caliper
Any help would be really appreciated because i need to drive it and done wanna pay drug money for a shop to look at it
https://www.sau.com.au/forums/topic/462690-brake-fluid-leak-help/
Take your wheels off where it's leaking and clean the discs, calipers and lines with brake cleaner. Once it's all completely dry, start the engine and pump then hold the brake pedal a few times. Then go back to the brakes and have a look where the leak is coming from. You may be able to see if it's coming from the line itself, the connection of the line to the caliper or the piston.
The problem is it never leaks when the car is stationery, when it picks up speed and I brake there's the hissing noise and it spits fluid, but only when it's moving
There's a little fluid around where the line goes in but there's fluid on the edge of the disc aswell and I can't see how the lines could leak onto the disc
It doesnt make sense that it only does it when you're driving. Follow Dark26's excellent advice, just make sure you press the pedal as hard as you would when driving. Also don't discount that it could even be the new lines.
  • Like 1
I sat there and pumped it for a while and I can feel a tiny amount under the lines, so I'm replacing the lines, I agree it doesn't make sense but whenever I try it never gets at wet as I expect so I just dismissed it.
Still I'm baffled that fluid from the lines can make there way onto the rotor
If you pump it up a couple times how is it any different to braking while driving? The only difference is the pads are doing their job
It's not exactly different but you may be braking differently in your driveway than when you're driving. You haven't said how long you were holding the brakes in the driveway so I'm assuming that while driving you're holding the brakes longer for stops. If I went for a short drive for testing, I would probably slow down to almost stopped from 60 about 5 or so times by the time I make it back around from all the T intersections/corners I have to turn at. It may not seem like much but you may not be braking the same amount in your driveway as you do while driving, that's where I think the difference is. Try pumping the pedal a few times and then hold it down with firm pressure for about 10-15 seconds, if you don't notice anything repeat this a few times.
Well my current thinking is the lines, I did find paint flaking from the area and looked into whether the 34 lines are right for the conversion and it seems the 34 calipers have a much deeper fitting for the lines, I'm thinking this isn't making a good seal since half the thread is exposed
33 lines are ordered so we'll see if that's it because two sets of good Nick calipers failing can't be a coincidence
Are your new lines the same type of connection as the calipers? When I fitted some GTT brakes some years ago I had to convert from banjo to screw in type (or the other way round - can't remember now) and had to remove the olive from inside the caliper.
I think Bob's on the right track.
There are 2 fitting type, one has a flare on the end of the brake line with an angled end that seals on a similar angled end in the caliper (the "olive" Bob mentions). The other type uses a banjo bolt that seals with a copper washer between the head of the bolt and a (hopefully) flat part on the caliper where the bolt screws in.
If your brake line has the copper washer/banjo setup it needs to seal tightly to the caliper, and it won't be able to do that if the banjo bolt bottoms out on the original fitting before it is tight.
So to check that you can look at the copper washer; they are designed to crush a little when they are tight.
The stock ones didn't use a banjo bolt, just an unnecessary bracket thing, but they screwed in fully whereas the new lines have this hardline tube coming from the threaded part which stops it screwing in more than halfway
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
