Due to constant pressure from the missus(Also needing deposit for a house) Ive decided to put my pride and joy up for sale.
here is a quick run:
162659km on chassis
Built 2.6L (7000kms)
JE pistons
Spool Rods
Nitto crank ollar
Billet Gears (oil pump)
Tomei 260/270 9.15mm cams
cosworth valve springs ( I think)
Tomei cam gears
Custom made oil catch can/power steering reservoir
ARC Intercooler
After Market Radiator (Not sure of brand)
Braided lines(oil/fuel) with speedflow fittings
Aeroflow fuel rail
turbosmart 1200v2 fuel pressure regulator
ID1300cc injectors
Microtech flex fuel sensor
microtech fuel pressure sensor
microtech oil pressure sensor
Microtech dash display unit
microtech LT16C
Proboost T04z/0.82 rear with billet 11 blade wheel
5ltr surge tank running 2x bosch 044's fuel pumps.
18" Volk TE37's with federal 595
blitz I color EBC
Engine was built by Graham Harrison of Turbowerx Brisbane.
that's all I can think of atm. car is currently making 470hp @14psi on pump E85.
cam gears have not been dialled in and has not yet had a proper tune.
few lil scratches and small dints here and there around the car but overall is in pretty good nick considering age.
couple small electronic issues aswell. Interior dashboard light/front left headlight. 4wd/ABS light is on. 4wd currently not working.
Im located on the southside of Brisbane
wanting $28500 ono
please contact me if interested or want more info cheers
Te Hore 0416 388 007
https://www.sau.com.au/forums/topic/462693-90-bnr32-gtr-white-470hp-14psi/
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
    • Mate, I take this thread in random directions on occasion myself, so no foul I'm a old fan of MCM anyway, I like their banter, and enjoy most of the stuff they do
    • Something strange is happening. I didn't touch the car since we last spoke on the forums. Yesterday was the first day of good weather, so i took it out for about 2 hours. It started up on first crank every time about 5 times total. I literally didn't do anything to do the car.
    • I purchased this one. Very well priced and works great. I was rough with it to see if it will last and had no issues.  Teslong Two-Way Articulating Borescope with Light, Industrial Endoscope Inspection Camera with Articulated Probe, Flexible Mechanic Fiber Optic Snake Scope Cam for Wall Automotive Engine Inspect-5FT : Amazon.ca: Industrial & Scientific
