Ever been to smorgasbord restaurants?
Ever watch li'l kids drop utensils only to pick them up and get some more?
Ever see the kids lick their spoons and put them back in the serving trays?
Could this be why Dennys, Sizzlers etc go out of business?
TBH i think Sizzlers went out of business because the food was horrible lol
  • 3 years later...
1 hour ago, PanoramaLife said:
I also had a bad experience over a cup of coffee. I had coffee at my favorite cafe and washed it down with the water they serve with the coffee. I suspect it was raw tap water...Because half an hour later I was running through the park in search of a toilet. It's such an unpleasant experiment when you enjoy life in your favorite cafe without expecting any trick.
What the f**k
^^ forum is global...tap water not drinkable in many countries, thank fk for AUS life. Now...>>
16 hours ago, tanokosohana said:
I got poisoned in a restaurant once, but I didn't make a scene. Moreover, it didn't stop me from going there again. Although my friend says I'm weird.
yes I too was poisoned, by the Russians in a restaurant during the Cold War period when I was a spy working for ASIO. I'd tell you more about it but you know, classified, covert ops, Call Of Duty Modern Warfare, that sort of thing.
  • Haha 1
    • I would sell those side feeds before you hydra-lock a motor. I won't say too much about Yellow Jackets because I'll hurt people's feelings, however ask those that tune RBs day in/out what they think of them.
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
