Located VIC 3978.
$9500. Price negotiable.
Selling due to need for 4x4 for work related reasons and to be completely honest, all the car needs is a financially stable owner. Due to a string of bad luck I've been unable to maintain employment for more than ~ 4 months at a time since purchasing the vehicle.
More pics @ instagram.com/cevlol
1993 Series 2 GTS4 sedan, white.
Engine:
152xxx K's (speedo swapped out, original one f**ked).
Fairly stock RB20DET
Turbosmart boost controller.
Remapped stock ECU.
42mm Alloy Radiator.
Custom FMIC w/ Ford core, shorter piping, more spool w/ brand new Proflow joiners + brand new hose clamps. No BOV, can plumb one in with silicone T piece for RWC.
New water pump less than 7k's old.
Full 3" turbo back w/ 3" dump/front pipe, stainless steel exhaust w/ high-flow cat & rear oval muffler. Note is 1hunnid.
Brand new genuine Nissan oil filter, less than 1000k's ago.
Brand new Motul Chrono Ether 300V 10W40 motor oil, doesn't need to be replaced for 9,000k's.
Brand new BCPR6ES plugs, less than 1000k's ago.
Interior:
Brand new R34 V-Spec Aluminium Pedal set.
Brand new Superior Auto Creative Carbon shift & handbrake boots.
Brand new Nissan shift knob.
Factory Series 2 GTST/GTS4 seats in very good condition.
Factory GTST/GTS4 steering wheel.
Exterior:
Brand new R32 GTR N1 front bar w/ eBay FRP vents.
Brand new R32 GTR N1 front reo.
Brand new Bosch Aerotwin Flat Wiper Blades.
VGC genuine R32 GTR front lip, could use respray but otherwise perfect cond.
Average condition R32 GTR wing FRP, minor hole one side.
Driveline:
R32 GTR rear shocks.
R32 GTS4 factory shocks.
HICAS lock bar / eliminator kit.
NISMO strut brace.
Brand new Exedy HD Organic clutch, freshly machined stock flywheel, less than 1000k's old. Penrite full synth in box atm.
ATF in transfer case/ATTESSA.
Custom 4WD/RWD toggle switch for sliding fun, don't use it often to be honest. Car stays in 4WD most of time.
Brand new Nismo R32 GTR slave cylinder.
Brand new HFM R32 master cylinder.
40% RWC tyres on R33 stockies.
Misc:
$1000 alarm system. Remote central locking, immobilizer + alarm.
Receipts from myself + last two owners.
High level brake light fitted to clear RWC fault as GTR wing is aftermarket.
Headlight loom completely rewired, no f**k arounds. H1/H3 combo w/ T10 parkers.
$3000 worth of sound gear, including Dynamat throughout. Can remove/include for adaptive pricing.
Bad:
Needs respray imho. White is 326 Crystal White but rough on quarter panels (in touch up paint atm, still very nice looking). Bonnet clear is well, peeling.
2nd gear very minor crunch. Could benefit from Redline treatment.
Input shaft bearing noise when clutch not pressed, goes away after 5 min drive. Very common issue that does not affect performance.
Reply here and/or email: [email protected]
Mobile outta order atm, changing carrier.
No swaps, unless you have a dope D22 Nav w/ 150k's or less (friend's selling me his for $9k).
Edited by Cev
  • Like 1
Price drop $7,500! 100% my loss ... brand new clutch, 300V & most of interior :)
I start my new job as a residential builder on 15th! Need this gone so I can pick up my Nav aka. work ute!
Cheers,
Cev
Bump, comp test done today. 150 across all 6 cyl ~ 5-8%
Call 0421 559 655 to express interest.
Bump n' stuff.
Still available, $6,500.
Will only need passenger side CV boot clamp for RWC.
Call 0421 559 655 ~
Cheers,
Joe
Edited by Cev
Bump.
$6,000 this week, without sound system.
Replaced broken coilpack clip with brand new replacement.
Will need passenger side CV boot clamp for RWC & potentially BOV.
Call 0421 559 655 ~
Bump.
Still up for grabs, $6,000 cash.
Car needs following for Roadworthy Certificate;
- front passenger CV boot clamp/grease, CV boot is fine, no tears -- $30
- BoV plumbed into current FMIC piping using Silicone T piece -- $80
- *potentially* may need stock intercooler if RWC inspector fails current custom setup -- $100 max (I can lend you a stock intercooler for RWC).
Call 0421 559 655 !!
Need this gone THIS WEEK so I can grab a Navara I've been after for work!!
  • 4 weeks later...
$4500 and ill pickup wednesday
No longer for sale, unless you're willing to pay $11k with Reg/RWC, gearbox reco'd, and R33 GTR wheels.
ie it's now my daily because low ballers and down syndrome's made me keep it!
  • Like 1
  • 4 weeks later...
Bump, back up for sale. $7000 ono.
-Club Reg-able in 2018. Will still be clean asf, rustless shell if you maintain it.
-HKS return flow intercooler added to car, custom FMIC setup removed. A/C can be refitted. (photo below is the HKS FMIC, NOT my car in photo).
-Redline Shockproof Lightweight gear oil has been added to remove second gear slight crunch, worked flawlessly.
-Brand new Osram Nightbreaker Ulimited H1/H4 low/hi beam added w/ Phillips 4300k parkers.
Call 0421 559 655 with offers/interest. Don't lowball, I'll hang up on yo ass and pretend I have bad reception.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
