I noticed there are Nismo instrument clusters for the earlier V35's, which show the speedo going up to 280km/h, as opposed to only 180km/h. (They also have the Nismo logo which looks awesome) However they apparently require the Sat/Nav package, which unfortunately the V35 I'm importing doesn't have. Does anyone know if it's absolutely essential to have the Sat/Nav package, or if there is another option for an aftermarket instrument cluster showing the speedo going above 180km/h? If not, I don't suppose it's possible to take out the Sat/Nav components from another V35, say one that is being scrapped for parts (Already seen two on gumtree which both have the Sat/Nav package) and get it working, has anyone ever tried this?
I'm not planning on taking it anywhere near 180 km/h on the street, but in the future it would be cool to have the option of tracking it once or twice for fun, so it would be useful to have the option of seeing speeds above 180km/h. Plus, having the Sat/Nav package just makes the car feel more "complete", even though it's not useful in Australia. (I understand the speed is also electronically limited to 180km/h but can be removed, would this be defectable?)
Sorry if these question has been answered elsewhere, couldn't find anything with the search function however. Thanks for any information!
P.S. My V35 has a manual transmission
Edited by Arycama
Haven't heard of any swap, try getting the model of the 280kph one and buy for ebay. If you can work a multimeter you might be able to hook it up but i think it uses a different loom to the 180kph. and don't worry about the speed, its not limited, and if you run turbos or superchargers it will go above 180kph
There are two models as the navigation model uses the dash for CAN data, to display the leaf etc. I think either should work in the non nav model, but don't quote me.
What? Where did you come from with that nonsense?
Are you referring to me saying that the Nismo cluster only working with the Sat/Nav version? It says so here:
https://www.japanparts.com/parts/detail/1197
"**ONLY for MY2004/11 and before with genuine TV/DVD Navi equipped model."
As for the "limited to 180 km/h" part, I can't recall off the top of my head, but read that Japanese street cars are electronically limited to 180 km/h.
If either of the above are incorrect, let me know. Or were you referring to something else when you said "where did you come from with that nonsense"?
What does CAN data stand for?
Controller Area Network. It is a fairly standard data bus used in most modern cars so each electronic component can communicate with each other. Some manufacturers use unique protocols, for some components, thus the vanilla type OBD2 readers won't talk to those components.
And as above.. the 'nonsense' statement was likely directed at the idea that these cars aren't limited to 180.. and the suggestion that the Nismo cluster uses a different connector.
The Series 2/3 cluster uses a different connector to the Series 1, but as long as you get the nismo cluster for the correct series, the connectors should be the same.
All JDM cars are limited to 180km/h by law in Japan. you will need an ECU reflash, or aftermarket ECU to remove this.
Not something else - someone else ... pretty much everything that Taine said. Takes a bit more than a multimeter and continuity testing to be sure you get it right. All Japanese vehicles are speed limited to 180km/h and as for having to use forced induction to see beyond 180km/h, well... (nah, I won't go there)
And CAN stands for Controller Area Network, used by a variety of equipment outside of the automotive realm as well, but it's all about carrying control data around in motor vehicles predominantly as a means of minimising the wiring required since every device transmits and listens on the same wires, waiting for its turn in accordance with the ID transmitted at the head of each data packet before it responds accordingly.
All good, thanks for the replies so far. How do I tell what series my V35 is? It's a 2003 350GT coupe. As far as I can tell, the nismo cluster is only for models before November 2004, after that the instrument panel was refined.
^^ this.. clusters are quite different. S1 has speedo and fuel gauge on the left, tacho and temp gauge on the right. S2/3 are the other way around.
I don't know if they actually made a nismo cluster for the S2/3?? someone might be able to correct me there.
    • The car revs up through the gears much better/faster now, and fuel consumption doesn't really seem to have be affected either on a Hwy cruise, which wasn't expected  The FAB9 intake manifold has been problematic sourcing though, I've contacted Plasmaman to ask about their intake, which you can get different runner lengths spec'd, and, their different options for throttle bodies  The only real physical drawback with the Plasmaman intake is how to connect it to my current OEM style airbox, as FAB9 make a OEM style back half of the airbox to suit the larger diameter throttle body, and all that is required is a 30°bend silicone pipe to mate the throttle body to the airbox Car also goes in for some exhaust work in a week or so to fit the biggest resonator they can fit clearance wise in the front pipe to help remove some of the drone, there isn't alot of realestate under there, a rough guesstimation is it will only be about 3-400mm long and maybe 90-100mm diameter, and with a 60mm exhaust that doesn't leave alot of space for the internal volume of the resonator to do its thing I'm thinking I may need to bin the "high flow" 100 cell cat for something a bit more substantial, yeah, and restrictive, like a 200-400 cell, to help, but, I have ample room for a really large bodied cat to replace the current one which has around a 4" diameter body I may look around in the recycling bins and see if I can find a massive newish cat that was "replaced" with some new full exhaust system that the local exhaust shop in Western Sydney is doing
    • Hahah look at that smile 😂 Just like those ones on IG where they compare the husband in family photos vs husband going fishing lol. I don't think I'll participate this time, clutch isn't in and also the last time I went there were too many numpties on the cruise sessions. Nearly caused a few accidents holding up people and a few guys initiating massive kerb to kerb drifts with heaps of cars right behind them. Not to mention, there were guys on the track session using it as a power cruise session.
    • Is there an actual website thingie for peoples who don't have Facebooks? Cheers
    • All Jap Day is coming up again! 13th of July this year. Are you going? Tickets go on sale on Wednesday 6pm. Please let Quang know as well. https://m.facebook.com/photo.php?fbid=1163155775853542   I still get shit from my wife for this photo because it is the happiest she has ever seen me. And it's not with her, it's in someone else's car.   Quang's EVO is sick, but that rotary wagon flying past was absolutely bonkers.
