Hi guys I'm just looking for some assistance in identifying possible problems with my 32.
It is relatively stock with a Blitz return-flow FMIC, 3" Dump to High-Flow Cat to 3.5" catback and I believe the stock turbo wound out to 11 psi.
It recently underwent a head rebuild after a blown head gasket. (Radiator was replaced with 32 GTR item and thermostat was replaced with Nismo item)
After the rebuild it was still spewing a bit of white smoke out the back but that gradually decreased until it stopped altogether after about a month. (You could always tell when it was about to spew a bit of white smoke when the car did it's 'rumble' under deceleration, when you get going again, out comes just enough smoke to see it rise above my spoiler in the rear view mirror)
A few weeks after the rebuild I noticed it had started leaking coolant from one of the hoses underneath the intake manifold (above the starter) after I would turn the car off. This happened a handful of times at the beginning then stopped for a month or two. At this point I'm not certain if there's a pinhole or if the clamp just isn't on properly, but when it started again I was able to wriggle my arm under the manifold enough to feel the hose that is leaking. I I am ashamed to admit, I still have not done anything about it.
I kept driving the car until last week when I've started noticing a puddle of coolant under the car every second or third time I drove it, directly beneath the overflow tank.
Note: I've always been checking my fluid and oil levels since the rebuild and have even bled the coolant from the bleed screw until bubbles stopped. Also, I haven't noticed any mixing of oil & coolant yet, I changed the Greddy (1.3 bar) rad cap for a GKTech (1.3bar) one after the rebuild too.
Yesterday I found I have to top up the radiator with about 2 cups worth of coolant and drive to work. (I know I probably shouldn't have)
Before I drove home that arvo, checked the rad again as it looked like that hose had been leaking again and found I had to add about another cup of coolant, do so and baby it home.
When I got home, left the car running in the garage for about five minutes (couldn't get hot air from the fans either), turned it off and checked the overflow to see if it would boil over again, but noticed it bubbling up all forthy in the overflow like when someone adds too much detergent to the sink, but didn't flow over this time.
Come back to the garage later after letting the engine cool down and check the rad, it has lost a little more coolant but can still see it above the fins.
The car still drives quite fun otherwise, no white smoke for months and the temperature gauge still sits in slightly above centre.
I plan to get that hose replaced, the coolant system flushed and pressure tested, cylinder compression tested and a leak down test performed if compression is bad.
If someone can recommend the closest workshop to Mount Gravatt East with a good rep fir working on Skylines that would be great. Otherwise I'll go back to the MIDAS that was quite honest with me recently.
I'm freaking out that my HG is on the way out again. (Oil and Coolant still look OK, no milky residue)
I guess I'm just looking for confirmation from people who know better, or suggestions on what else I should be doing.
https://www.sau.com.au/forums/topic/462715-r32-gts-t-coolant-issues/
it sounds like air in the system due to your coolant leak. Fix leaking hose/clamp first. U should be able to do that yourself, just takes a bit of time for that below manifold stuff, its not that hard. give it a go. Unlikely to be hg again unless engine was severely overheated or job done was dodgey. Don't freak out yet. Fix leak, thoroughly bleed system and monitor. Hopefully happy days and big skids.
  • Like 1
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
