Hi guys I'm just looking for some assistance in identifying possible problems with my 32.
It is relatively stock with a Blitz return-flow FMIC, 3" Dump to High-Flow Cat to 3.5" catback and I believe the stock turbo wound out to 11 psi.
It recently underwent a head rebuild after a blown head gasket. (Radiator was replaced with 32 GTR item and thermostat was replaced with Nismo item)
After the rebuild it was still spewing a bit of white smoke out the back but that gradually decreased until it stopped altogether after about a month. (You could always tell when it was about to spew a bit of white smoke when the car did it's 'rumble' under deceleration, when you get going again, out comes just enough smoke to see it rise above my spoiler in the rear view mirror)
A few weeks after the rebuild I noticed it had started leaking coolant from one of the hoses underneath the intake manifold (above the starter) after I would turn the car off. This happened a handful of times at the beginning then stopped for a month or two. At this point I'm not certain if there's a pinhole or if the clamp just isn't on properly, but when it started again I was able to wriggle my arm under the manifold enough to feel the hose that is leaking. I I am ashamed to admit, I still have not done anything about it.
I kept driving the car until last week when I've started noticing a puddle of coolant under the car every second or third time I drove it, directly beneath the overflow tank.
Note: I've always been checking my fluid and oil levels since the rebuild and have even bled the coolant from the bleed screw until bubbles stopped. Also, I haven't noticed any mixing of oil & coolant yet, I changed the Greddy (1.3 bar) rad cap for a GKTech (1.3bar) one after the rebuild too.
Yesterday I found I have to top up the radiator with about 2 cups worth of coolant and drive to work. (I know I probably shouldn't have)
Before I drove home that arvo, checked the rad again as it looked like that hose had been leaking again and found I had to add about another cup of coolant, do so and baby it home.
When I got home, left the car running in the garage for about five minutes (couldn't get hot air from the fans either), turned it off and checked the overflow to see if it would boil over again, but noticed it bubbling up all forthy in the overflow like when someone adds too much detergent to the sink, but didn't flow over this time.
Come back to the garage later after letting the engine cool down and check the rad, it has lost a little more coolant but can still see it above the fins.
The car still drives quite fun otherwise, no white smoke for months and the temperature gauge still sits in slightly above centre.
I plan to get that hose replaced, the coolant system flushed and pressure tested, cylinder compression tested and a leak down test performed if compression is bad.
If someone can recommend the closest workshop to Mount Gravatt East with a good rep fir working on Skylines that would be great. Otherwise I'll go back to the MIDAS that was quite honest with me recently.
I'm freaking out that my HG is on the way out again. (Oil and Coolant still look OK, no milky residue)
I guess I'm just looking for confirmation from people who know better, or suggestions on what else I should be doing.
https://www.sau.com.au/forums/topic/462715-r32-gts-t-coolant-issues/
it sounds like air in the system due to your coolant leak. Fix leaking hose/clamp first. U should be able to do that yourself, just takes a bit of time for that below manifold stuff, its not that hard. give it a go. Unlikely to be hg again unless engine was severely overheated or job done was dodgey. Don't freak out yet. Fix leak, thoroughly bleed system and monitor. Hopefully happy days and big skids.
  • Like 1
    • Hello First, I apologize if this is not the correct forum. Let me know and I will move it to the correct one. I'm having a problem with the tachometer on my Skyline R33 with an RB25DET Neo engine. I'll tell you from the beginning. I'll tell you from the beginning. I have the RB25DET Neo engine installed in a Nissan Patrol GU, with a Link G4X control unit specifically for that engine,  and I have fitted a Skyline R33 tachograph to the original GU dashboard, but it doesn't work properly. I have the tachometer connected to the positive and negative terminals of the GU panel's wiring, and the signal cable is connected directly to the ECU output pin, but the rpm fluctuates widely. Can anyone tell me if the output signal from an R33 ECU is the same as the output signal from an R34 ECU, or if the voltage and signal type are different? Regards and thanks.
    • I guess it was the thought about "Oh if I were to drive this everyday". Then no, SL500 I wouldn't really consider lmao.
    • Yeah actually really fair point. Idk what I was thinking when looking at the SL500. Now that I think about it, I feel like I would have more enjoyment out of a shitbox that I would need to repair than some fancy merc. Although I must admit the SL500 does look quite nice. My bad hahaha.
    • 100% Also "Not wanting to spend money" is THE WORST IDEA IMAGINABLE when coming to a project car of any kind. They EXIST to BURN MONEY. Sure, gas money is a thing. A stock car with the worst fuel economy ever sold would probably be cheaper than modifying a car with FREE petrol for the life of your ownership of it, lol.
    • Amount of time you're being observed by law enforcement is so minute, that you could be a dumb shit 90% of your driving time, and never lose a demerit. You could also be the best driver ever and still get hit with a fine.   When you realise how quickly everything turns from "Wee, we're having fun!" To "oh f**k oh f**k oh f**k", you start to realise the only way to be a good driver, is to not be doing anything dumb or unexpected by normies on the road. You want to go fast, go to the track. Someone there in a 1990s slow POS will also show you how bad of a driver you are as they lap 10 seconds per lap quicker than you can in a car that should be considerably faster.
