12631417_10154574670614386_3394745165168
SAU Vic have been accepted to take part in the 2016 Australian F1 Automotive Avenue Car Club Display from the 16th to 20th of March.
Being one of the biggest events on the Australian motorsport calendar this is a great chance to show your pride and joy along with experiencing what the F1 has to offer.
SAU Vic have been given 10 places so there are limited spots available.
To enter send your name/forum name along with a little info and photo or two of your car to -
[email protected]
Make the subject 'F1 Display' so we know what the email is about.
Submissions close 19th of Feb and we will contact successful applicants by email after that date with more info on the event.
Just a couple of things to consider -
*Cars must remain inside the event between bump in on Wednesday the 16th of March and bump out on Sunday the 20th of March.
*Successful entries receive 2 passes to the F1 that cover all 4 days
https://www.sau.com.au/forums/topic/462720-sau-vic-2016-austrlian-f1/
Excellent news.
Presume this is for club member cars only? Vic/interstate alliances?
Do you have a specific theme in mind or should everyone apply - spectrum of Skylines/GTR, clean stock, highly customised, show v track etc then you'll decide on club theme once see the entries?
  • Like 1
Great to see, I work there every year and on!y see the Nissan owners club cars which are pretty average. Can't wait to see some clean and/or full-on skylines / gtrs.
Would put my name in, but I would want to see skylines in the SAU stand, not my s14-gtr cross
  • Like 1
Would love to but cant risk car getting damaged/scratched unless you guys are planning to rope the cars off?
There will be barriers between cars and spectators, here is some info from the F1 Motorsport & Entertainment Department who are running the Automotive Avenue -
- The vehicles on display will have rope and pole barrier positioned around them to prevent patrons from touching the vehicles during the event. However, it is the responsibility of each owner to ensure that no patron approaches their car during the event. Some clubs provide an ‘onsite’ support person to manage this process, as well as being able to provide information on the Car Club.
- Roving security will be in place during each event day and night in the area of each Automotive Avenue location.
- There will be no coverage provided to the cars from rain or dust, however, each owner has the option to cover their vehicle during the course of the night. All covers are to be removed prior to gate opening the next morning, which occurs at approximately 10.30am on each day of the event.
  • Like 1
Got to ask as you say you can't risk it getting scratched - do you stay home and look at it in a garage? :-)
Stays in a locked garage almost all the time. I try to avoid shopping center car parks. I try to find parellel parking wherever I go so I don't have to park next to anyone :)
Fark parallel parking worries me the most. People openly swing car doors into other cars but people's depth perception when reversing in front of you is worse I reckon :/
  • Like 1
Know that one, I parked up in Tidal river 50mtrs away from the main bunch of parked cars and someone still managed to drive in to the side of mine - plus didn't leave details
  • 1 month later...
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
