hello everyone
so here is the thing
engine fresh rebuild new rings new bearings done 600km
engine is standard
fuel system standard
afm standard
cams standard
exhaust : tomei manifolds and dumps y pipe + sard high flow cat + 3inch exhaust to the end kakimoto
turbos hks gt2530 with 19psi hks actuators
car wont make more than 330-350 Rwhp on dyno dynamics , full boost is 5k rpm maybe even more
this is not what i expected , we played with timing etc but its stuck on 330whp range and it feals quiet slow untill 6k rpm when drove it and i havnt driven more than 150hp car for past 2 years and still felt slow :)
all dyno graps i have seen are getting more horses and happy with full boost by 4k rpm
anyways some your input would be great
first thinking remove sard cat and put straight 3" cat , do i really need camshafts rght now? i am not planing to go higher boost yet just want get most out 19 psi
thx
Exhaust is choking it for one. It's way too small.
Ditch the lot and build yourself a 3.5 inch system (minimum) with decent (universal) mufflers and try again.
Cams ain't the problem unless when it was put together one of the cams are a tooth out. Seen it before on a mates car.
Rag in cooler piping? Lol
Standard fuel injectors and punp run out of flow at 270kw (360hp)
Standard air flow meters are out of range at 300kw (400hp)
Exhaust needs to be around the twin 3in into a 3.5in with no restrictors in it (most Japanese cat backs have restrictors in the mufflers) put a decent 100cpi cat in it cause the sard ones aren't much better then a factory cat
And put some cam gears in there and use them to get some good gains through the rev range
thx for reply guys
i will remove sard cat and will fit 550cc injectors and see how it goes , not sure why it so late on full boost , mafs and fuel pump should be good for that boost? should i be getting around 400rwhp on 19 psi at list?
forgot to mention egt is 900-1000c , isnt it a bit high?
thx
Why would you just replace the cat when the rest of the exhaust isn't up to the job either? a restricted exhaust will slow down response and send temps through the roof.
The fuel pump is at least 14 years old, do you really want to risk pushing its limits?
If I had 2530s and only making 300kw (400hp) I would say i chose the wrong turbos for my needs
Replace the whole system. Like Brett said above
Why waste time going from 444's to 550's?. Get a set of modern 1000's Atleast.
The reason modern 1000s are being recommended is that there is really no downside, since they respond well at low pulsewidths so idle etc are fine.
For MAFs you can tune past the 300kw limit, but in that range the ECU is guessing what the fuelling should be, so you're risking over or under fuelling. Nismo MAFs bolt in and are good for ~370awkw, which is about that the 2530s make on pump, so would be a good option.
Something is up for sure...
I made 550hp at the wheels on 23psi with a 2.5 inch to 3 inch twin front pipe and a 3 inch blitz nur spec catback. Didn't have a cat though. So exhaust size isn't your issue. Bigger is always better, but its not choking you at that power level if its a healthy flow path.
Collapsed cat?
Power fc,700+cc injectors, decent fuel pump and z32 afms should be on your shopping list for sure. Those turbos are a waste without suporting gear at the least.
Edited by burn4005
Collapsed cat?
you see 4psi differensce 200hp more , so thats why i am not happy at all
i do have that list for summer not earlier ;) i just cant do all that stuff right now , r35 mafs , injectors , cams , gears , clutch , pump etc is on summer shopping list not yearlier
thx everyone
just to clear things up , i refresh engine , all gaskets, seals , rings , bearings , reimax pump etc , while engine was getting done i purchsed rutbos and put them on when instaled engine back , my plan was to tune it on stock boost and drive 2-3k km ("brake in time thats how u call it ?:)"). for the summer i would buy all suport mods to push tham to the end . that is why i left stock fuel system on fresh engine , to go high power wasnt my goal .
so car is on dyno and lowest boost it takes is 19psi , didnt think it would be that high , so started tune on 19psi , no boost controller no restrictir removed etc , at the end 330-350 not remember in that range was max we couldnt take out of more no metter what i did . yeah worst part is full boost takes forever to hit !
Ecu is nistune .
all i can do right now is borrow injectors from friend and remove sard cat at all and see were it goes
got recomend to dump my hks iridium spark plags and put ngk bcpr11 ones? maybe i should swap ecu as well? power fc ? i dont know i am just very disepointed
