Hybrid Performance Turbo Manifolds For Rb25det Neo R34 Gtt
taz2069
 Share
just wondering if anyone has used a manifold from hybrid performance, im looking at getting one from them just wondering if there are any quality issues? im looking at a top mount with no wastegate
If you are referring to the Hybrid Performance manifolds from NZ - Google and you will find a number of posts (there is a thread on here somewhere).
In summary I think people believe they are value for money (were quite cheap ) although some people said they had to plane the mating surfaces flat.
I run one on my car, and saw another one on another track R chassis car this weekend gone.
There are no complaints about mine, very functional if maybe not having the same bling factor as some other brand names. No issues with fitment or build, although it doesn't look to be in the same league as (say) a Full Race.
Somewhere in a build project you've got to draw a line on finances, and if you don't require absolute top end performance I'm sure one of these will do the job at a reasonable price.
ive been running one for around 3yrs or so 510rwhp with manual
now running built auto with 450hp with same manifold seems fine.
wouldnt hurt to get surface faced for perfect seal.
mines a tiny bit leaky but cant be bothered removing it.
  • 3 weeks later...
Not everyone does FB.
Photos show a few drag times and some sound gear install plus a pod filter, so maybe a long way to go?
Expect comments about planning/costing the whole upgrade, with all the gear required to fuel and tune the beast plus transmit the drive.
Are you on tighter budget? 4 turbo options that would cover 380-450rwhp (by Australian figures) would be BW 7670, Kinugawa T67, GTX3071, or something out of Stao's ATR43 range.
well since the canadian dollar went to shit against the us dollar my original plan had to be postponed my plan for the car is to use an n57 bmw diesel with a v160/161 getrag supra transmission, everything im doing right now is just to have a bit of fun until the dollar is more reasonable. i have the type b poncams being installed as well as an n1 water pump aluminum rad with 2 - 12" fans, i think i have found a turbo now Arashi TD06H-AR3, i also have a rc-turbo neo intake and throttle body on order, and am just waiting on hybrid performance to have a manifold ready to be able to order it.
BMW diesel engine into Skyline?
This deserves a fabrication/build thread!! Do it.
Meanwhile do a bit of searching on this forum for turbochargers. Quick google search, it seems like the Arashi is similar to some Kinugawa/Kando units on offer. A bit like the case with Mamba branded units. On a 2.5 litre you might find a T67-25G or TDO6SL2-20G more useable than something running the TDO6H turbine.
Well right now I only have a stock automatic transmission and I have to keep that in mind when buying parts until I get either a stock 5 speed or get the v160/161 getrag. the arashi is a good price at 950 Canadian shipped to me. I don't really have a budget for upgrades just what ever will work with this transmission for now. And my mechanic prefers Japanese built equipment and I trust him in that regard as he has built lots of high horse power skylines over his many years
Edited by taz2069
 Share
    • The two diagrams are equivalent. The R32 one is just one sheet out of about 3 showing everything in the whole car all at once. And without knowing the functionality that occurs in the modules, they are both equally opaque.
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
