I would like a price on the radiator brackets in BLUE please to match the engine covers. I have a Stagea 260RS AUTECH so I'm not sure what you can fit on them in the space.
any ideas would be great
Stagea Autech 260RS 016
Another thing is I need a badge for my grille where the AUTECH VERSION badge was originally, there are 2 pins on the back of it.
Stagea Autech 260RS 033
Stagea Autech 260RS 014
Hi Shaun,
I will PM details through for the radiator upper support brackets. Anodised blue is fine - on the front face we have roughly 36.00mm x 13.00mm for logo work, text etc depending on character size qty will determine if we can machine it.
In regards to your decal badge etc - we would require outer dimension so we can draft something for you. We can incorporate many design aspects into the badge for you.
Thanks
  On 15/06/2016 at 4:19 AM, Outcast said:
IS it say possible to do one in say the R you can put a 4 and gts
Gts
4
Say like that
Hi Josh,
Sure can - a GT R style badge with the upper letters as GTS with a large number 4 with the red centre inlay.
Mint as any chance u could do a purple inlay and make one say for the grill and the rear Ben Sam size as the gtr one inbox me and I've got cash, etc just don't have a drawing etc of it be happy if u could make something up?
  • Like 1
Thats Fine,
I will draft some up for you to review - purple is fine - we could even splash some metal flakes if you like - each to there own
I will PM the drafts through - not sure I will get a chance tonight working on a big project for a customer - should be through tomorrow sometime late arvo.
Thanks
  • 1 month later...
  • 4 weeks later...
hi mate
can u do a 25 30 badge. 25 on top of the 30 same size as the gtr badge on the front of a 33 gtr
and the 25 30 like tbe R below but in black?
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
