I'm aware it doesn't work in AU without various conversions etc (I did read the "Read before posting" thread after all), but having fuel consumption info etc. would be handy, plus it looks cool! I'll still be getting a double DIN unit with Sat/Nav, Bluetooth, touchscreen etc regardless. The pop up screen is just a nice touch, plus gives a few options for future modding, such as having Ipod album/artists displayed on it, or a reverse camera.
The other main reason I was asking is because the Nismo instrument cluster apparently only works if you have the Sat/Nav installed.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
