hey guys,
i've got an r33 and last week the car lost so much power. when i put the foot all the way down, it just revs and basically goes nowhere. I've tried pumping it with injector cleaner, fuel system cleaner but nothing seems to work. If anybody has any ideas as to what may be the problem, could you please let me know.
Cheers,
Antony.
https://www.sau.com.au/forums/topic/46282-power-loss-in-my-rb25de/
its something to do with the clutch in the auto or it could be the gearbox i had the same problem with mine but it was a manual as soon as it got to 4 rpm it would go straight to redline without me moving and it was because the clutch was worn and it was slipping have it checked by a mechanic
i have the same problem with my car. Its a 92' r32 GTS RB20DE auto. Did u find out th eproblem and how to fix it? very keen on the solution, as i am a Noob. it is my first car, and its been this way since i got it.
although a bit of an increase in power as the engine warms up.
Also, there seems to be a new engine noise which has just recently come up. somewhere between 2-3000rpm theres a vibrating noise, which sounds like somethings loose.
Any tips on what it is or what i should do? mind you i am a Noob.
  • 3 weeks later...
I have taken it to a few mechanics but unfortunatly have had no luck. No one seems to know what the hell is goin on. Its got nothing to to with the gearbox, apparently, i thought it may be the coils, but its not them, the next thing thats gonna be looked at is the cat to see if its blocked or not. Either way i'll keep you guys posted. If any body out there knows of a good mechanic who knows what they are on about with skylines and are in melbourne, could you please let me know.
Cheers,
Antony
PS. Anut, my car is exactly the same, increases in power as it warms up, sometimes it even goes back to being normal, but as soon as it gets cold, it starts all over again, and i do get that same noise around that rev range. I am trying to get to the bottom of this.
ill have the afm checked out, but i was told that if it was the afm, there would be heaps of smoke coming out of the exhuast, as for the fuel, its using heaps more, im pushing it if i can get somewhere between 250 & 300 kms from a tank using optimax. I would normally get somewhere between 450 & 500 kms
Does yours make like a loud sucking noise at cold start between 2000-3000rpm BOTH when accelarating and just after when stepping off the gas? Mine does this and i've got the stock air filter and air box still, no pods (i know pod does this). And it stops doing it after the car is warmed up like at normal temp. Can there be an AFM problem, like its on its way out?
nismo_GTS keep us posted wat happen to urs ok.
Cheers
Mine makes that noise but i have a pod, i have managed to book the car in for monday, the mechanic reckons he's gonna need the whole day to find out whats wrong, we'll see how we go. I'll let you guys know whats goin on whatever happens.
Cheers.
The exhaust will make a snappy vibrating noise in N/A's and it has been layed down to a charicteristic of the engine, something along the lines of the cams, should be most prominaent around 2500-2900ish.
I had a problem with mine a little while back where the engine would cut out and react like it was hitting redline fuel cut, but would do it as low as 3500rpm, esp the hotter the engine became, this turned out to be the exhaust cam sensor. Which is a mitsubishi part (Mitsu sabotage!!) i wasnt happy because the very same time it stop working, was the same time my car was sitting on the dyno, i was very pissed off. My car hit top of 96kw @ wheels, but due to the sensor cutting out at 4000rpm, and anyone with an N/A knows this is where the real power only starts to build up, i had another good 2500-2800 rpm left to pump out my power figure, i was not a happy boy.
Cheers.
Hay man did u find out wat the problem is?
:D
Hey guys. This is becoming really frustrating. The last guy i took it to doesnt have any idea whats goin on. He suspected that it might be the cat thats blocked but after putting it up on the hoist and checking out the temperature difference from one side of the cat to the other wich was only a few degrees, he said its in good nick. I am convinced that is something to do with the exhaust. Im going to change the cat anyway on the weekend and clean the pod out.
Cheers
P.s I really appreciate all the tips you guys have been giving me so far, thanks guys
    • Yeah everyone always seems to refer to them as S13 wheels however they came on R32 Skyline, A31 Cefiro, C33 Laurel etc., and also came polished diamond cut or painted depending on the model. Congrats on your GTS purchase! I'd personally leave it NA.
    • In this thing about this 100% renewal energy stuff I hear no one really talking about anything other than power and fuel really Power and fuel, whilst being a huge part of how we use the billion year old Dinosaur juices, are only 2, of the probably thousands of things that we need to use it for in the chemicals industries for making nearly everything we use nowadays I'm all for a clean planet, but if we want to continue to have all the day to day appliances and stuff that we rely on everyday we will still need fossil fuels Whilst I do love science, and how it can bring innovation, there's really a limit to how far it can go in relation to "going green" As for EV's, unless your charging of your own solar panels, it isn't helping the environment when you consider the the batteries, the mining processes required,  the manufacturing process required, and how long a batteries (read: the vehicle) lasts long term If I was supreme dictator of the world, I would ban the use of sugar for fizzy drinks and food additives and use that for ethanol manufacturing, petrol engines would be happier, and people would be alot healthier  Disclaimer: Whiskey manufacturing would still be required, so says the supreme dictator of the world Same same for all the vegetable oils that get pumped into all our food, use that for bio diesel Disclaimer: the supreme dictator would still require olive oil to dip his bread in This would take some of heat off the use of the use of fossil fuels which are required for everything we use, unless you want to go back to pre 1800 for heat and power, or the early 1900's for plastics and every thing else that has come from cracking ethylene  Would I be a fair and just dictator, nope, and I would probably be assassinated within my first few months, but would my cunning plan work, maybe, for a while, maybe not Meh, in the end in an over opinionated mildly educated arsehole typing out my vomit on my mobile phone, which wouldn't be possible without fossil fuels And if your into conspiracies, we only need the fossil fuels to last until a meteor hits, or thermonuclear annihilation, that would definitely fix our need for fossil fuels for manufacturing and power issues for quite some time  Meh, time for this boomer to cook his lunch on his electric stove and then maybe go for a drive in my petrol car, for fun
    • It really helps that light duty vehicles have absolutely appalling average efficiency due to poor average load. Like 25% average brake thermal efficiency when peak is somewhere around 38% these days. So even a 60% BTE stationary natural gas plant + transmission and charging losses still doing much better with an EV than conventional ICE. And that's before we get into renewables or "low carbon nonrenewable" nuclear which makes it a no-brainer, basically. In commercial aircraft or heavy duty diesel pulling some ridiculous amount of weight across a continent the numbers are much more difficult to make work. I honestly think in 5-10 years we will still be seeing something like the Achates opposed piston diesels in most semi trucks running on a blend of renewable/biodiesel. Applications where the energy density of diesel is just too critical to compromise. CARB is running trials of those engines right now to evaluate in real world drayage ops, probably because they're noticing that the numbers just don't work for electrification unless our plan is to make glorified electric trains with high voltage wires running along every major highway and only a token amount of battery to make it 30 miles or something like that after detaching. Transport emissions is not insignificant especially in the US, but yes there's a lot of industrial processes that also need to be decarbonized. I agree the scale of the problem is pretty insane but EDF managed to generate ~360 TWh from their nuclear reactors last year and this is with decades of underinvestment after the initial big push in the 70s and 80s. I don't think the frame of reference should be solar-limited. France is not exactly a big country either. Maybe it doesn't work everywhere, but it doesn't have to either. We just can't live off of fracking forever and expect things to be ok.
    • Yeah, all the crude is used for fuels and petrochem feedstocks (pesticides, many other chemicals, etc etc). But increasingly over the last few decades, much of the petrochem synthessis has started with methane because NG has been cheaper than oil, cleaner and easier and more consistent to work with, etc etc etc. So it's really had to say what the fraction either way is. Suffice to say - the direct fuels fraction is not insigificant. Heavy transport uses excruciatingly large amounts. Diesel is wasted in jet heaters in North American garages and workshops, thrown down drill holes in quarries, pissed all over the wall to provide electricity to certain outback communities, etc etc. Obviously road transport, and our pet project, recreational consumption camouflaged as road transport, is a smaller fraction of the total liquid HC consumption again. If you're talking aboust Aussie cars' contribution to the absolute total CO2 production of the country, then of course our share of the cubic mile of coal that is used for power generation, metallurgy, etc adds up to a big chunk. Then there is the consumption of timber. Did you know that the production of silicon metal, for example, is done in Australia by using hardwood? And f**king lots and lots and lots of hardwood at that. Until recently, it was f**king jarrah! There are many such sneaky contributors to CO2 production in industry and farming. NG is used in massive quantities in Australia, for power gen, for running huge water pumps (like, 1-2MW sized caterpillar V16 engines running flat out pumping water) for places like mine sites and minerals/metals refineries. And there are just a huge number of those sort of things going on quietly in the background. So NG use is a big fraction of total CO2 production here. I mean, shit, I personally design burners that are used in furnaces here in Oz that use multiple MW of gas all day every day. The largest such that I've done (not here in Oz) was rated to 150MW. One. Single. Gas burner. In a cement clinker kiln. There are thousands of such things out there in the world. There are double digits of them just here in Oz. (OK< just barely double digits now that a lot of them have shut - and they are all <100MW). But it's all the same to me. People in the car world (like this forum's users) would like to think that you only have to create an industrial capability to replace the fuel that they will be using in 10 years time, and imagine that everyone else will be driving EVs. And while the latter part of that is largely true, the liquid HC fuel industry as a whole is so much more massive than the bit used for cars, that there will be no commercial pressure to produce "renewable" "synthetic" fuels just for cars, when 100x that much would still be being burnt straight from the well. You have to replace it all, or you're not doing what is required. And then you get back to my massive numbers. People don't handle massive numbers at all well. Once you get past about 7 or 8 zeros, it becomes meaningless for most people.
    • @GTSBoy out of the cubic mile of crude oil we burn each year, I wonder how much of that is actually used for providing petrol and diesel.   From memory the figure for cars in Australia, is that they only add up to about 2 to 3% of our CO2 production. Which means something else here is burning a shit tonne of stuff to make CO2, and we're not really straight up burning oil everywhere, so our CO2 production is coming from elsewhere too.   Also we should totally just run thermal energy from deep in the ground. That way we can start to cool the inside of the planet and reverse global warming (PS, this last paragraph is a total piss take)
