Greg Posted September 24, 2004 Share Posted September 24, 2004 seriously - clean your air filter. I was ready to replace my whole exhaust system, but after cleaning the air filter it was fixed. Don't spend money replacing the cat if its ok!! Link to comment https://www.sau.com.au/forums/topic/46282-power-loss-in-my-rb25de/page/2/#findComment-1025463 Share on other sites More sharing options...
LOW25T Posted September 25, 2004 Share Posted September 25, 2004 no way its ur cat dude... if the engine is revving out and your not going anyway, there is some problem in the drivetrain, more than likley your auto box Link to comment https://www.sau.com.au/forums/topic/46282-power-loss-in-my-rb25de/page/2/#findComment-1025706 Share on other sites More sharing options...
FATGTS-R Posted September 28, 2004 Share Posted September 28, 2004 RTHRTY3: If you are getting a sound that is like you have a pod, but you dont have one, it might be a leak in your inlet tract. Check all hoses for leaks and any cracks from the airbox to throttle body. nismo_GTS: If you want to rule out the filter being dirty as the problem, just remove it altogether and go for a spin around the block. Link to comment https://www.sau.com.au/forums/topic/46282-power-loss-in-my-rb25de/page/2/#findComment-1028920 Share on other sites More sharing options...
BBQ Posted September 28, 2004 Share Posted September 28, 2004 Your auto will be slipping; Best bet is to take it to a mechanic that deals with Auto cars. He can diagnose it from their. If not check your fuel filter/replace it. They can sometimes cause that. Link to comment https://www.sau.com.au/forums/topic/46282-power-loss-in-my-rb25de/page/2/#findComment-1028935 Share on other sites More sharing options...
RTHRTY3 Posted September 30, 2004 Share Posted September 30, 2004 RTHRTY3: If you are getting a sound that is like you have a pod, but you dont have one, it might be a leak in your inlet tract. Check all hoses for leaks and any cracks from the airbox to throttle body. umm an update, from inside the car it sounded like a sucking noise from a pod, but when you open the bonnet up and listen to it from the front it is more like a scraping noise and is coming from the front half of the engine near the water pump or cam cover area. makes the noise both on and off acceleration between 2000-3000rpm, and the funny thing is it goes away once the car is warmed up and is at normal running temp. :confused: any ideas? Link to comment https://www.sau.com.au/forums/topic/46282-power-loss-in-my-rb25de/page/2/#findComment-1031442 Share on other sites More sharing options...
