As per Iron Chefs FB post linking to this article - http://www.theguardian.com/business/2016/feb/10/australians-to-bypass-car-dealers-and-import-directly-from-japan-and-uk
Are we all expecting that to have a good or bad impact on import prices?
Easier access will hopefully mean more competition, but more demand might also see prices not drop.
I wouldn't mind an R35 down the track and I'm guessing they will be cheaper for us under this scheme, but in turn that will drop the value on my 34 perhaps.
https://www.sau.com.au/forums/topic/462833-changes-to-import-laws-good-or-bad/
Can somebody please clear this up for me? I'm a little confused after reading the article.
The 12k (approx) import duty is going to be removed...is this only on cars that are over 25 years old?
JPY9.6 million for 2016 gtr
Much better than the ludicrous local price
A few R35 owners are going to see some rapid depreciation.
I wonder how much of an issue the lack of localisation will be (switch gear etc) or more importantly how quickly the aftermarket will fix that issue.
  • Like 1
But you'll still have to pay LCT, GST and stamps,plus rego,transport costs. You'll also lose some on the money exchange. You'll quickly find that the Aussie prices of R35 are pretty spot on, ie not a rip-off.
Mark X for me :)
Yep, it does looks nuts. Finally a Toyota that looks cool.
http://gazooracing.com/pages/gs/markx/
$53k at todays exchange rate for 3.5l motor but I haven't factored in bringing it to here maybe add $10k?
I've been doing a bit of reading, it seems all everyone cares about this scheme is cheaper cars that's already available here.
I reckon we should get excited to the fact we can get some cars that aren't available here originally like latest Civic Type R, Seat Leon Cupra (heaps better than Golf GTI), Mark X, Alphrad, Vellfire and such.
I'm sure there'll be more cars out there that people will want.
  • Like 3
i would like to see what actually happens with LCT,
im in the auto industry and lct is a huge player for cars.
at the moment LCT needs to be paid ON NEW CARS, but the grey area which we play, a used car does not pay it but if a "demo car" is registered under a dealer the lct flows down to the first owner, but a used car does not apply, so its the first registered owner of the "new car"
so if a used car (500km 12 month) car comes from japan, i dont know if LCT will be applied or not, big difference if you wanted to buy a $300,000 car for instance.
hopefully the actual effect is not against the dealers but the manufactures. they might need to stop charging the Australian market (the retailers... not the consumers) more for cars that are sold cheaper overseas. its not the dealers fault that we get a higher price, we do not make more money that our overseas counterparts, their are not higher margins, probably lower.
we are the P'platers of the world market, we get what we are given and that is a small part of the available line up and we generally miss allot of the specs given to all ofther countries, Then we are charged the Australia tax because we have no choice.
if a Nissan dealer can finally sell their cars for the same price as japan, im sure they would be happy. it also means that they will give us models we couldn't not get before due to pressure of lost sales from the dealer groups.
i once spoke to a Nissan high up from japan through, we complained that we couldn't get certain models that that Australia should be looked after he response was this.
we can make our entire year of Australian delivered vehicle in one day, if the Australian market became to hard to deal with, we can just take a day off"
as a jap import consumer, its all sorts of giddy good news, but im honestly hoping, from an Australian industry point of view that it dosnt become damaging, because it has the potential to go either way. its defiantly going to cause some adjusting and i hope it does create a free'er more open, consumer driven market. but spare a thought for the businesses behind it which may get damaged.
Edited by GH05T
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
