Hey guys, I did a bit of searching around but couldn't find specific answers for this;
What would be a more suitable oil in a stockish R34 GTT - Royal Purple HPS or their new XPR oil?
It seems the XPR is a on up from the HPS, specifically for performance racing, does that mean it would not be suitable for a daily jap turbo?
This is what their website has to say; (useless)
http://www.royalpurpleconsumer.com/right-synthetic-oil/
https://www.sau.com.au/forums/topic/462838-royal-purple-hps-or-xpr/
I use hps 10w 40 In my turbo territory as its supposed to be the more daily driven oil choice with more detergents than the xpr which has higher zinc and less detergents but has a boiling point of up to 400degc from what I read from there data sheet. Both are at least a group 4 which is the more important factor here I reckon.
The ultra high performance oils (XPR, Motul 300V competion, Redline Race series) are very good in terms of dealing with high heat, high strain conditions
however this is only 1 of a 3 part equation - the are;
1. Heat tolerance - pure performance
2. Cleaners, detergents and additives - ongoing engine maintenance / protection for cold starts
3. Oil longevity (suitability for longer time/km intervals)
You have to remember racing cars differ to street cars in the fact that they;
- oil is constantly changed out every event - meaning it does not require a complex detergent/additive package to clean the bearings etc.
- constant changing also means the oil does not need to last very long time/kms wise
So the reality is the best oil for track is not the best oil for street
What you will need to settle for is an oil with a moderate heat/sheer tolerance, but also have a detergent package + resistance to acidity to last and clean over a 5000, 10,000 or 15,000km interval
If you still wanted to spend upwards of $80 my picks would be Redline (normal series) 10W40, Motul 8100 Xcess or Amsoil 10w40 (Motul and Redline are available at most Autobarns)
Good options under $50 are Penrite HPR10 (when on sale), Gulf Western Syn-X 3000, Castrol Edge 0/10w40, Valvoline SynPower 5w40
An great medium is the Gulf Western Syn X 6000 if you can find them in Autobarn, or buy direct - they are very close to your full Group V(5) ester based oils like Amsoil, Redline, Motul 300V, but at a fraction of the cost, around $50-60 i believe
Hope that helps, everyone wants the best for their ride, just need to adjust your understanding of oils to make a more informed decision
  • Like 2
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
    • Turbotapin   so I am about to be mounting mine up been waiting for the body to get finish at paint. I had a question. I was told our Speedo sensor it originally in the transmission but the cd009 is in the diff on the z. How did you get around this?
    • I definitely do recommend having a fab/grinding/dirty shed or area to keep all that grinding dust out of your main shed.  But you're right, it doesn't matter how much room you have you still end up filling it! I might even do a short video which will make it easier to fully take in the horrors of what I've created...
