It's already been said, but is their sufficent flow through your raditor? If it is at idle and cruise speed then check radiator for blockages etc. Also check that nothing else is mounted in front of the radiator that is producing hot air flow (e.g an oil cooler with 100 degree oil running through it is going to heat the air before it hits the radiator)
When you say driving, is that just street driving or hard driving?
Yes I know that kiwi, I think you need to re read my original post. No matter what temp thermostat I put in it, it still idles at 84deg. The current thermostat I have (65deg) should be regulating the idle temp to 65ish degrees but it's still sitting at 84.
And yes I have properly bled the system.
OK I have re-read your original post and it seems you do not understand that once a thermostat has opened then it has no ability to regulate the temperature (unless you are operating in freezing conditions when it might close again). That is why regardless of the opening temp of your thermostat ( and you say you have tested them and they open as advertised) your operating temperature remains at 84 deg. Talk of "headroom' is a blind alley. It only takes a few minutes of hard use to raise temps quickly and cooling is only available by the radiator and oil cooler. Problems can be caused by blocking of the radiator by oil cooler and intercooler placement, or some fan arrays and can be ameliorated by air ducting and turbo or exhaust wrapping.
You can easily test the operation of your thermostat in situ. Turn the car on from cold and feel the waterhose. Let it idle and you will be able to tell when the thermostat opens as the hose will suddenly become warmer. Check your water temperature gauge. After it has warmed up the radiator if your temperature continues to rise you can rule out the thermostat as the cause since once its open it can do no more to reduce the heat.
    • @Kinkstaah yeah I initially checked with Chequered as I've used them with a previous car. But they have stopped sourcing and installing Nistune chips. They only do tuning now. I did not want to pull out my ECU and send it away somewhere to have the chip installed. That would mean no driving the Skyline
    • Should have checked that.  On the plus side, I got my Bluetooth adaptor.
    • Each province differs a bit but we only do mandatory vehicle inspections here for heavy vehicles (Think Ford F350 and up). Those inspections are done by mechanics that are approved by the government. Besides that, it's a free for all as long as the car looks stock.  I asked because I love seeing how engineering differs from country to country. Here in Canada, all designs must be stamped and signed before they can be brought to fruition. (I.E Bridges, structures, Electrical panels, machines, literally everything shy of a wooden table) This can only be done by a professional engineer or professional engineering technologist. Both are protected titles, but the latter having more of a limited scope in what they can stamp. To become a professional engineer, you must complete a 4-5 year bachelors degree in your field of engineering, be part of an engineering order and undergo 4 years of apprenticeship, testing and mandatory continues education. Same story for engineering technologists, but a 3 year associates degree in some form of engineering technology will suffice. If you do not comply, or pretend you're an engineer or technologist, off to jail you go. If you stamp a design that fails, off to jail you go. If you stamp a design that fails and kills someone (I.E Bridge collapse) Off to jail you go for a very long time, your family will be ridiculed on the news, neighbours will surround your home with pitch forks and your dog will disown you.  Same for specialised trades... Example Electricians must undergo 1.5 years of post high school education, 4 years of apprenticeship, testing and hold proper licences. It's for the best, but then we also wonder why we're so short on engineers and tradesmen haha. We also have professional engineers who were only school smart but have no idea how a drill works. They generally go straight into management roles out of school which is also for the best.
    • Not currently, I'm at the school where we teach people to build bridges and other fun things that involve making, or breaking things
    • I have a friend who has used Chequered Tuning and CMS. Went to CMS when Chequered had a long wait time which is kind of the norm (for good reason). Was very happy - I'm pretty sure the very simple thing you're asking will be simple.
