Hi
At the moment when I click on a link in a post, a new tab opens with the link (that part is perfectly fine) but it also follows the link on the current tab which is in SAU. So I end up having two tabs with the link open and no more SAU
Not sure if I need to do something or if it is a site problem?
Thanks
https://www.sau.com.au/forums/topic/462870-links-in-posts/
Are you guys still having this issue?
Its on and off for me, sometimes its broken and other times its not. Eg, this thread works fine; http://www.sau.com.au/forums/topic/463086-2016-infiniti-q70-review/
https://www.sau.com.au/forums/topic/462870-links-in-posts/#findComment-7688383
Doesn't happen with that particular one, although it happens with the GS F review you posted before. Strange.
https://www.sau.com.au/forums/topic/462870-links-in-posts/#findComment-7688438
  • 3 weeks later...
So, Invision admitted that there is a bug causing this.
They also said they wont fix it because it requires "advanced support" that ceased 15 days ago.... (after only a 3 month "no more support" period for our version announced in December.)
So .... f**kers wont help.
I'll continue to look into it guys but I'm kinda driving blind.
  • Like 1
https://www.sau.com.au/forums/topic/462870-links-in-posts/#findComment-7698886
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
