  • 3 weeks later...
Seriously. We get it. A lot of you guys don't like fitment/hellaflush/whatever you want to call it. Fine. No worries. Doesn't mean you have to bag on EVERY f**king person that asks a question related to it. Kinda tired of reading it to be honest.
I may not like everything you do to you cars, but I won't talk shit about you or your car for doing so.
To the OP, I ran 18x10.5 +15 on my 33, quite low, some camber and a rolled/flared guard. Used a 235/40 rear tyre too. Had room for wider if needed, but not much more.
Edited by R31 drift pig
  • Like 2
https://www.sau.com.au/forums/topic/462890-r33-fitment/#findComment-7695896
This.
Looks unreal! More pics?
https://www.sau.com.au/forums/topic/462890-r33-fitment/#findComment-7695898
To the OP, It'll just need a good roll/flare in the back, 235/40, 245/40 or a 245/35 tyre, it'll fit fine. Yours will sit 5mm further in, which is equal to pulling 1 degree of camber out. 1 degree negative = 5mm top of wheel in.
If you get a bit aggressive with the roller, you could pump enough to fit a 265/35 if you wanted to, which was my plan, but was easier to fit over fenders.
Hope that helps. :yes:
https://www.sau.com.au/forums/topic/462890-r33-fitment/#findComment-7695909
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
