2006 V35 Knock Sensor Fault Code Problem
Search for your VIN in gtr-registry.com and see what it left with from factory. There's 4.3:1 and 4.11:1 diff ratios IIRC, can't remember what models had what. Also could be tyre size, by factory the speedo reads a tad quicker >80 km/h but constantly out be 10 km/h is weird. Maybe someone wound the odometer back, and accidentally bumped the needle up?
Single 3.5", 5" metal body cat, centre offset oval muffler in the middle, large rear oval muffler straight through.
I ❤️ Clark Rubber Pretty much all the stick on foam stuff or pinch weld shapes and sizes you could possibly need
