2006 V35 Knock Sensor Fault Code Problem
Ok the LCD popup screen has a message "pitstop" .
obd check came up with
bank 1, knock sensor.
It only has 1 knock sensor so it cant be the knock sensor, given bank 1 only problem!.
O2 sensors,, I swapped em sides, fault stayed on bank 1, so they should be ok.
The A/F sensors look hard to get at, and possibly need a special spanner?.
Anyone ever removed these A/F sensors, How hard ??
Coil packs, manual test procedure looks to be very hit and miss???.
And injectors need the plenum removed , last resort job there!!.
Anyone have any input, ideas to solve this issue ?
Note.
O2 = middle of cat converter sensor
A/F = above cat converter.
Pitstop doesn't mean anything.
It's just a resettable oil / filter / wheel kilometre counter. Doesn't mean there is an engine code.
Knock sensor I wouldn't worry about it the car is driving fine. Check the wires to it are intact, have been cases of mice eating the wiring in there.
Reset the fault code, and see if any check engine lights come on.
  • Like 1
The pitstop message has been cleared 4 times now & won't go away.
Seems to be more than a maintenance related problem, thanks for the input.
simply putting it out there to see if anyone else had struck a similar issue, & or had some pointers for possible cause and or tell tale signs to look at.
More input the better!.
The ecu is leaning the engine off as a result of knock detected.
Edited by nobby
ECU won't lean the mix if knock is detected.. it retards timing and richens the fuel mix, resulting in poor performance and poor economy.
  • Like 2
Thanks for that, I have been away for a while since the obd unit was connected.
So I can't remember the data , the $3k OBD device my mate owns, he told me it was leaning off.
Tell us how you are clearing the pit stop message please?
On my mates obd, Autel unit 3k worth.
Looks like a tablet, and does way more than just check and clear etc.
Perhaps the engine is knocking because there is low fuel pressure, due to a blocked fuel filter? If it detects crazy knock it may throw a code...
I haven't looked at this yet, will soon. thanks.
Well, that's the reason your pitstop message isn't going away. It has nothing to do with the obd port/reader/whatever.
You need to go through the menus and reset the service reminders. I take it you don't have the English conversion??
  • Like 3
spot on!!!
  • Like 1
Ok thanks for that, No I don't have english conversion for lcd screen.
Are you able to walk us through the steps any way??
Soon as I finish typing I going to reset mil manually and see what happens.
Mil is throwing 2 codes.
knock and throttle control relay.
The autel unit only picked up on knock code, but the relay code may be new as it recently had a flat battery, and low power may of caused it, fingers crossed,
And have a look at jap menu see " If" I can work it out anyway lol.
Thanks for the help gents.
There is no throttle control relay. I suspect the Autel is having issues reading Japanese. :P
Sounds like it would be easier to find a mechanic that knows these engines, shame you are too far away for me to help, but I suspect the front wideband O2 sensor is buggered or an injector is blocked.
  • Like 1
Thanks scott, take it the "front" wide band is the top a/f sensor?.
Blocked injector was my first thought but pita to get at, hence putting it out there for another opinion.
Humm no relay, wiring diagram is showing one in section PG page25, but not identical box layout to whats in my car.
wiring dia show 15amp fuse and relay then throttle motor. so this is why I was looking at this.
but to be honest it didn't make much sense about a faulty relay the car drives and not bad at that, and fair mileage about 10/100k.
would of thought if a power relay for throttle was faulty it plain wouldn't of started & or run very badly etc.
Edited by nobby
Ok pit stop has been cleared.
noticed when pitstop message appears -- then I pressed enter nav button, it was cycling between 2 messages top left of screen.
then I noticed in information page a similar messages.
press nav enter again.
a page appears with 4 slide scales on it.
the slides when you press nav enter again can be reset to zero by nav toggle left and enter.
then Itoggled down to next slide scale and continue to reset again.
I reset all 4 scales to zero.
started engine and pit message gone.
Now I am laughing.
But it wouldn't of happened without the input from others, Thankyou
Edited by nobby
F####### now it's gone into limp mode.
And I can't seem to access mil by tapping the go pedal,( in a bit of a bind 1 may say).
guessing go pedal sensor is at fault this time.
lucky! I was about 1k from home when it happened, 1kph max for the trip back.
max revs were about 1200, and then couldn't get up the drive way.
ahhhhhhh
Edited by nobby
You can usually get a little more acceleration if you push the pedal to the floor, but only a little. Turning the ignition off and on can reset the fault, I had to do that while driving down the freeway a few times when using dodgy pedals sensors.
Been in limp mode too many times to remember. :P
 Share
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
    • NO HITS PRICE DROP   ENGINE - $8.5k ONO TRANSMISSION - $1.8k ONO
    • If it has had a code in the recent past, the code should still be there waiting to be read.
