Hello everyone! Received a nice salary package so I've decided to buy a brand new car. That being said, I'd like to let this beauty go to clear some debts and start fresh!
I've owned this car for 1 year to date and it has just been serviced using premium Royal Purple Oil.
The car has 58xxx genuine kilometers which have all paper work to vouch for.
This car is near perfect, drives immaculate, everything works exactly as it should and is like butter on the roads.
This is the JDM Skyline Type SP, has every bell and whistle accounted for which include;
Bluetooth
Paddle Shifters
32g hard drive with cd burning
Reverse camera
Passenger side parking camera
Front and rear parking sensors with physical read out of what your close to
Driver and passenger heated seats
Dual climate control
Many many more factory options.
Mods I have done include:
Eibach Prokit suspension
Custom Exhaust for mad tone
Loudz Creations custom head light housing and genuine RGB Angel Halos with remote control
20" Koya Sf06 flush fitted.
Custom Twin Pods moved to front of radiator for maximum airflow, set up like Stillens.
This is an absolute incredible machine that drives like new. Turns heads every single place I go, people staring out their cars to see what it is, or hear what is coming down the road.
I'm asking for around 32,000 as this is one of the cleanest genuine Ckv36's on the market with very REAL low kilometers. Slightly negotiable as within the year I've put 5k into it and you wont find one really anywhere close to this for the price. Feel free to text me at 0427 89 7793 as I work full time so wont be able to take calls but I WILL get back to you.
Alternatively email me at [email protected] Located Adelaide!
https://www.sau.com.au/forums/topic/462928-2008-ckv36-type-sp-370gt-for-sale/
Its just a respect/homage thing for being japanese. In japan car scenes would steal them off subways (hand cables) and hang them off cars as a sign of being a rebel to taunt cops. I just did it cuz the car is jdm. Only others who know the history of them would get it so i understand it looks wankery to others. :P
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
