Hey so i have googled and searched through the forums quite a bit and would still like a second opinion. For a while my 34 was having coil pack issues, one cylinder not firing occasionally and sounding like a truck/loss of power. The other day i was driving as per normal and all of a sudden under throttle i was losing all power and felt like MASSIVE drag so i pulled over. At this point it was idling fine and would rev through the rev range perfectly but once in first gear id take off normally and after about 2 meters it would have a huge power loss and drag. I managed to get the car home 2 meters at a time as i didn't want to leave it on the street (really bad area) and then had to reverse up my drive way as it was the only way i could get it up there ( too much power loss in first but not in reverse). I let it sit for a bit and now when i start it it starts perfectly and then dies straight out. If i giver it some throttle it is fine but is spitting out black soot and will stall once it hits idle.
After hours of research i came up with the either AFM was not working, vacuum leak or faulty idle switch. So i pulled it apart the AFM and re soldered it and still no good. My question remains is the AFM faulty or is the idle switch faulty? any ideas? :D
Kinda losing my mind haha
https://www.sau.com.au/forums/topic/462964-r34-gtt-wont-idle/
So were 5 wet?
Was it running than you removed them so they could have gotten wet. Plugs that work will not be wet because they burn the fuel. If it was running rough than you pulled plugs than they could have a chance to get fuel on them on the cylinders that are not firing.
I had one stuffed coil pack and it made my car miss fire intermittently. One spark plug looked a little different in the fouling. Because it was only sometimes it had not changed the plugs appearance a lot. I changed all coil packs as my car has done 185000km and I just bought it so I don't know when they were last changed. Either they have done a great amount of KMs or they have been changed once before as they normally last about 100000km.
sorry for the late reply i have been away. All the other plugs looked perfectly fine as i replaced them maybe 4 months ago or so but one was black and dry none were wet. Just before i went away i found a rather big split in one of the main intake hoses and i have just replaced that but the battery is dead so i have to wait for it to charge to see if it changed anything. :)
So i started her up and she started fine and went to die. Gave a little bit of throttle and she settled on idle so i let her warm up for a bit. Revs through the rev range beautifully but now at idle she sounds like shes missing occasionally so i disconnected each coil pack one by one and it sounded worse every time so the coil packs arent the problem. This problem is unrelated btw it was doing this for a week or so before she died.
Went for a drive and she is pulling harder than she ever has been and my boost gauge was only hitting 7 psi instead of 10? Then i popped a hose that i must not have tightened properly but i lovely lady with a 200 sx came running out of her house with tools so could get it home haha
I know im just a little slow haha :)
I believe all my problems have gone away now after i fixed the boost leak and cleaned the IAC Valve. No weird idle and car has alot more power but kinda feels like it pulls back slightly once it hits boost. Thanks for the advice tho Hadouken was very helpful :)
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
    • Careful with posts like that around here without the flame suit on @cobo_11! 😂😂 My 330i journal is on here too. That car was so good and super reliable. We still have a 130i in the family which is almost identical to the 330i and easier to find in manual. It has also been almost faultless over the 6 or so years in the family.  I used to want an M car a lot more than I do now but if I'm honest and without trying to sound like a wanker, I can get such good performance and handling out of my 335 without needing to worry about all the crap that goes along with M car ownership. I don't need to worry about my bearings or subframe issues or the cost of replacing brakes or suspension or whether it has been impeccably maintained. And I can leave it places and not get upset when it's always filthy.
