I did mine myself, the only hard part was determining which ignition wire did what. You simply use a test light on the ignition wiring harness though and it takes 10 mins max.
Once you've figured out which color does what, you can splice into it any way you want.
The handbrake wire is obviously wired up to the handbrake and only requires removing the gear stick surround to find and tap into.
Its an hours work for someone with some electrical experience.
https://www.sau.com.au/forums/topic/46297-turbo-timer/#findComment-940654
