Hi guys just after some opinions from people who have done this.Now the story is a have an R32 GTR which i mainly use for 1000m airstrip time trials.The car has 1000hp and currently can run over 300kmph but the gearbox which is H pattern with a giken 1-3 gearset just doesnt want to shift fast at 9500rpm,poor thing,lol.So im in the process of ordering an OS88 but cant decided on which ratio.Im currently running 265 RSRs on R34 GTR rims which are about 24.4inches tall.Its pulling about 305kmph through the traps with the stock top gear(0.752) at about 9000rpm,so its close to maxed out.Now the plan is to run MT street radials 265s which have a diameter of 26.5 inch which will work perfect with the stock OS88 top gear(0.852).My question is will these fit diameter wise or will they touch the plastic inner guards?If they dont fit then i will lean towards a set of 265 R888s which are about 25.4inches tall and order the OS88 with the 0.75 top gear.So basically has anyone on here ran 18inch MTs 265s with stock inner guards?Any advice would be appreciated.
https://www.sau.com.au/forums/topic/462970-r32-tyre-diameter/
You don't want to take a wheel off and do the measurement yourself?
The only way to measure is to dummy fit some tyres if i can find some worn out ones someone doesnt want,but having trouble locating some so thought i would ask if anyone has previously run this size with success.Just didnt want to go blow close to $2000 and find they hit the inner guard,anyhow see what happens.
Are you sure that's the only way?
So what about cutting a disc of cardboard that is the right OD of the tyre you want to run, chucking it into the wheel arch and seeing if it clear shit or rubs shit?
No good doing unless the suspension is compressed to where it sits while driving,plus it will move up and down over bumps.Also need to do some full lock tests,so your method may give me a bit of an idea but wont gurantee all is good.Only way is to do a proper test with a tyre fitted or talk to someone that has run this size on this car already.Thanks for the idea but.
Standing kilometre, so he may well like the air flow control, but makes me wonder if he needs to turn the wheel very far.
True dont have to turn the steering wheel much,or thats the plan anyhow.After chatting to a few drag guys seems like they JUST fit so think i will just bite the bullet and take it on.See if we can crack the 200mph/322kmph mark this year with the new sequential box.
    • Clear vinyl wrap or clear coat?
    • There really needs to be an ODBII item that can play intake noise through speakers, synchronized with your current RPM and TPS%.
    • Worth most of the $50k alone!
    • So, we now have a straight and clean boot lid inbound and the car goes in for paint, again, on Wednesday, and will be ready on Friday, all ready to get cams and stuff on Monday  And by straight and clean.....I mean a brand new OEM one that cost..... $1300....😪 Sadly there's no clean undamaged used soft top version available, plenty for the power retractable hard top versions though, which is arse and makes Mark have the sads I could have waited longer, until a NC sort top boot lid eventually turned up, but I'm sick of waiting and said fark it and made it rain cash, meh In other naturally aspirated news, one of the guys at work brought in his old Corola which had a 4AGE in it, really nice clean car with lots of mods, including ITB's, man that things induction noise sounds sick with all of the dorts that makes you smile......maybe the NC needs ITB's, yeah, basically for the noise they make, but they're pretty expensive, but, they sound so damn good I may bring this up when I drop the car up on Monday, and by may, I mean I will🤣🤑🤪🤣
    • If you squint hard enough those horrendous barracuda wheels look a bit like r33 GTR ones!
