another workaround (if you don't know what the deadtimes are), set roughly what you think the dead times are..
set your VE on your fuel map to 80 or so then adjust the deadtimes till your AFRs are stoich.
Actually, better yet, get bigger injectors!
This is just to get motor run in and sorted.
That sounds like a good idea.
So increase the fuel map % so the highest is around 80% giving it better resolution?
^ no no no.. only the idle cells, it's just a way to determine the dead time at x voltage.
So what you do, set the VE to 80 for cells around idle 0 to 50kPA and 0 to 900 rpm. Start car, monitor the voltage then adjust the dead time till you hit stoich.
Of course all other VE cells will need to be adjusted to suit as the base map isn't really ideal.
alternativly if the ecu supports changing from sequential to batch fire have it running at a stable afr using batch fire, then swap to sequential if its leaner when sequential then increase dead times, if its richer decrease, and change back and forth like that until there is no change in afr
Setting idle fuel load cells with a VE of 80 on most engines would be throwing mixtures in the mid to high 11's and possibly even deeper into the 10's or more as VE is dependent on the VE of an engine, all are different.
if the engine has cams and some brappy overlap good chance you'll be adding way too much fuel in those load sites causing the car to stall at an instant. Instant plug foul.
I'm not sure how your example can give you a accurate dead time as dead Times need to be measured over voltage and fuel rail pressure.
that data cannot be obtained while it's running in a car unless you're adjusting your voltage in your car somehow and see no erratic change in your Afr.
Even then you'd still be guessing
Edited by mr skidz
  • Like 1
It's more of a guestimate way of setting it up rather than getting it precisely correct, many tuners have done that in the past namely PowerFC days.
Of course getting trade right data across voltage vs. lag time is ideal however it may be difficult to obtain data for stock side feeds hence the recommendation.
Many tuners do all sorts of things to get that I agree but it's called close enough.
80% VE at idle is not a good idea and you'll quickly be pulling plugs out from fouling.
The correct data would be voltage vs fuel pressure = lag time
I'm guilty of doing this, but if you drop the dead time enough you'll hit stoich on idle.
Yes you will hit stoich but choking you're dead times to decrease fuel supply to your fuel map is bodgie hard that's not the way to get your afr's correct and all your numbers will be ass about in your base map which is your foundation so it needs to be perfect before any subfolders are corrected otherwise you will chase your tail forever and never have anything working correctly.
so all your correction maps will never be correct.
Even cold start percentages like intake temperature corr and so forth.
If you put your high beams on I bet you your air fuel ratio changes?
this is what dead time is all about.
Edited by mr skidz
Yes I am 100% of all this, but if you have no data how else you going to set it?
With the high beam thing, easy go monitor your voltage and tweak the voltage vs dead time table when your head lights are on.
I've see a handful of tunes from reputable workshops that have a linear straight line as their dead times.
If your happy with close enough than that'll work. I wouldn't settle for that myself.
changing VE on base map to 80% at idle is not correct approach your best to Change the Dead times which is clearly the issue everything else is a band-aid approach that's all I'm saying.
Workshops do all sorts of weird and wonderful things unfortunately.
For every awesome successful build that happens I'm sure there's 10 that we don't hear of that are horror stories just saying.
Edited by mr skidz
Yes I am happy with that if I cannot find any data for an injector however these days everyone runs modern top feeds so the data is avaliable to just copy paste into a table.
If someone brings a car for me to tune with high flows I never use the data given, especially off Five O's site. Those numbers don't work at all.
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
