Adam,
A Borg Warner EFR8374 matches most of your requirements. Rated up to 800HP (79lbs/min compressor) and capable of well over 400kW at the rear wheels on E85. Available in 0.83 A/R T3 internal WG.
Garrett's GTX3582 is available in a T3 twin scroll but only external WG. However they do have a T3 0.82 internally gated turbine housing. It will produce less power than the EFR8374 but probably provide slightly better response.
Here's a back to back comparison between the smaller Borg Warner EFR7670 with a T3 0.83 vs. a Garrett GTX3582 T3 0.82 on a 2008 model STi running pump fuel with 50/50 water methanol injection:
Opt for the 400kW car... you know you want to :yes:
  • Like 1
https://www.sau.com.au/forums/topic/462977-turbo-choices/#findComment-7688077
There are other options that will meet 'most' of your requirements. But not many available with an off-the-shelf T3 internally gated exhaust housing.
Precision Turbo (Shaun is familiar with PT stuff) PT6062 CEA GEN2 (rated up to 750HP) is available with a T3 5-bolt housing which could be set-up to run internal WG. A little bit of stuffing about though.
Forced Performance have their new Xona Rotor range, which is basically their previous FP comp/turbine wheels with a new CHRA. But no off-the-shelf IWG option.
If you switch to external gate your options increase significantly.
https://www.sau.com.au/forums/topic/462977-turbo-choices/#findComment-7688262
6262, comes in a ford 1.06 in gate housing option ..which means a 6062 should fit aswell....
or people get them machined into the ford housing..so im guessing you could machine it into a .82 3582 in gate housing..?
cheers
darren
Edited by jet_r31
https://www.sau.com.au/forums/topic/462977-turbo-choices/#findComment-7688347
  • 4 weeks later...
Stock manifold will be a choking point, you need the motor to breathe.
If you want stock manifold, get a fabricator to run twin gates off it.. grouping cylinders 1~3 together and 4~6 together.. the factory manifold surprisingly is "nearly" twin scroll, bar that little notch.
OR use a Havoc Fabrication modded manifold which merges each of the pulses into 1x gate. I would expect at least a 45mm or 50mm gate off it.
GTX3582 would be perfect, especially with that 3.0L pushing it along.. heck even a GTX3576 would be perfect.
https://www.sau.com.au/forums/topic/462977-turbo-choices/#findComment-7700787
