Last chance to tidy up before next weekend. Got the drivers side harness in. Without the cage and harness bar I've gotta go back to using the back seat seatbelt mounts which I don't like but hopefully I can change that soon.
Fabbed a couple of bars to mount the front bar
On the sides I've got a bolt sticking down to locate and quick release tie downs
Tried to do the right thing and sell the gtr bonnet but no luck so we just cut some ribbing out where it fouled on the air intake, it weighed in at 7.5kg
Wheel alignment stats
Then a quick wash. Dummied up the side skirts. Photo op
  • 3 weeks later...
Small shitty update. Went to put it on the trailer for skid day.... And it wouldn't start. Cranked over fine and had fuel pressure but not injecting or sparking. Couldn't fix it in time, cracked the shits. Eventually put it down to missing washer jets in the bonnet = wet engine and plugs etc. dried out all the plugs, sprayed a bunch of contact cleaner, got spark and fuel back, new plugs an away she goes. Mounted the skirts and borrowing a guard roller tomorrow before lap dash at the end of the month at Wilby Motorsport park.
Pinched the diagnostic scan tool from work and aside from all the automatic transmission faults, it came up with a maf sensor code. I'll have to get my hands on a new one as it could be making it run real rich. Did quick oil change an then onto rolling the guards
or take it for a mafless tune... ;)
You could be right, you'd think they'd get rid of the maf sensor in the intake elbow if that was the case.
Another query. On the flat garage floor one four body stands. Front two on lowest hole resting on the chassis rail, rear two stand one hole higher, again on the chassis rail. The car is hovering above the right rear stand by a few mm. No cage in the car yet but it seems really stiff in the body. Absolutely no signs of any previous damage, barely had a scratch on it. All four wheels aligned perfectly but still looks like it may be bent?
I had a similar issue recently. I bought a damaged car and the front wouldn't sit right by a few mm. I then noticed the whole chassis was bent, probably from the impact of the hit (it was a big hit). Hope this isn't the case with yours.
Few teething issues on the day but pretty happy with the shake down.
I'd never balanced the front wheels an it had a bad wobble at high speed. Swapped them out for a pair of 18' I bought, they scrubbed a bit but no more wobble. I think it's got 30mm bolt on spacers, might need to go smaller or pump the guards even more. Came in after a good session and it went up in smoke as I pulled up (Photographer was lurking with a camera too)
Maf sensor wire got caught in the belt an it pulled the top radiator hose into the belt an cut it as well. Car ran fine without maf sensor so I'd guess it's maffless. shortened rad hose fine and ran the rest of the day with a half munched belt up front but it ran fine. Didn't cost me any track time which was good. Had shitty tires so it wanted to slide every corner but it's got a heap of punch if I can get it to the ground, really happy.
  • 1 month later...
Quick update. Lap dash this weekend, I've got the week off an a long to do list. I bought a set of rims with decent semi slicks for $300. Sold the rims for $200 so a steal if they're any good. They're about 5 years old an two are near new but understandably hard. I've order some Grip tyre softener from Racegear Revolution, hopefully that brings them up a bit. Clearance looks to be an issue again on the front with the wider semis so I've gotta take the 30mm spacers off. Might look at putting smaller ones on if there's room, not sure how advantageous they'd be?!?
I'll mount the tacho and shift light an see if I can pick up a pulse from the ecu somewhere. I've been told by an auto elec mate who's done LS swaps before that it can't be done, have to crack open the alternator and pick up a pulse in there. Another auto elec mate who LS swapped his S13 said there's a brown wire at the ecu.
I bought a HUD GPS speedo for $50 which was more accurate than a brand new Ranger an updated quicker than the GPS speedo in my phone, should do the job.
Most importantly, went to replace the main drive belt and realised the last one was the wrong size, fitted wrong which fouled on a bolt head, stripping it which caught the maf wire and top rad hose.
57a06f7a0eaa4_ImageUploadedBySAUCommunit
Glad to get to the bottom of that one, knowing it won't happen again.
I'll post some pics of the hack job custom dash etc tomorrow
Old man had an old set of wheel alignment ramps out at the farm which I helped myself to today
57a070d448979_ImageUploadedBySAUCommunit
Should make regular oil changes, tire changes etc a bit easier
Track day didn't go as smooth as it could but got some decent seat time. First session, two laps in got a flat on the right rear. Had to run scappys on the rear for the second session, took a while to heat up to get any kind of grip. In the third session the front left semi delaminated, blew out an fired me into the infield. I managed to get back onto the track and back to the pits.
57a914dc4d090_ImageUploadedBySAUCommunit
57a914eb63f54_ImageUploadedBySAUCommunit
57a914f753770_ImageUploadedBySAUCommunit
To get me through the last session with some form of traction I used the semi from the left rear onto the left front despite different rim size/offset and ran the last session trouble free. Car itself ran near flawlessly. Limited is set at 8500rpm but shift light can only be set at 6500 max. Finished at 1:02.5 in the last session, there would have to be another 1 - 2 seconds with decent tires and endless possibilities with a decent steerer. I've got a couple of vids if I can figure out how to upload.
Next up is a skid/motorkhana day early sept
Ended up buying more 2nd hand semis. Need to decide if 7*+ neg camber is usable or if I need to fit standard lower control arms. Don't want to scrub out new rubber doing heat tests.
The current rims are lenzo racespec 17x9 +30 front and 17x10 +15 rear. I just picked up a set of the same rims (4x 17x10 +15) with decent Nitto NT01s, the rims from Joogas LS13 I posted a pic of earlier
57b1c83fbec23_ImageUploadedBySAUCommunit
So I'll have the 4 10's on the car with semis, another pair of 10's with old semis as back up and a pair of 9's for desperate times or for making clouds
57b1c8f971cd9_ImageUploadedBySAUCommunit
I'm thinking I'll have to strip the current rims back to shiny alloy when I get time
  • 1 month later...
I've done a few more events, still working through some issues, the build continues.
First up we put on some scrappies for a skid day, was pretty flawless all day. Limiter bashed first all day
IMG_1474793557.731436.jpg.b142747447c29f
IMG_1474793580.018016.thumb.jpg.b23009df
Then switched up to full track khanacross which was a blast. My first attempt at linking a whips together on the track.
IMG_1474793662.763118.thumb.jpg.4e28d151
A mate picked up that we were down to 7 pots, confirmed with a temp gun. I couldn't pick it, neither did my old man which makes me think we've been on seven since we've owned it. Changed plug, coil pack and lead, one at a time, no change. Could be rings low compression, crook injector, wiring issue somewhere.
IMG_1474793870.890255.thumb.jpg.4e099343
Put the semis on for a lap dash today at Wilby Motorsport park. Sight lap proved the rears we gonna foul the guards pretty bad so had to switch to scrappies on the back
IMG_1474794019.127211.thumb.jpg.75ecc3a1
Only got one session in before I got called home with a crook family. One session was enough to take out the 4l plus/v8 class, 8th overall of a field of 21.
Cool down lap was taken in anger, binned it. I'd only just got round to making a front row strap extension.... Used it first time out. Reverse Murphy's law?
IMG_1474805369.765014.thumb.jpg.4b41407e
IMG_1474805390.288892.thumb.jpg.f9da72de
  • Like 1
  • 2 months later...
So time for an update. Took us until after the final race of the year to diagnose and fix the miss it had. The plug on top of that injector had the connector pushed up out of the way so it wasn't firing. The noid tester we used (and assumed it had pulse) had prongs long enough to make contact that we'd missed. Car had clearly been running on 7 since I've owned it coz it sounded like a completely different beast. Couldn't wait till feb 2017 to drive it so the boys hit up a test and tune day at Winton on Friday. Massive difference as soon as I pulled onto the track. Got a heap of track time in, I hadnt even been a passenger around Winton before so I made a lot of improvement from first session to last. Went from 1:46.XX to a 1:39.7X which I was happy with. Car ran solid all day, bit of extra guard rolling, brake overheating issues ect.
Still felt like there was a couple more second in the car as it took me all day to figure out a few sections with gear selection ect. Tires weren't great but did the job, still rocking over 7* neg camber.
Down the back straight, got to a top speed of a little over 180kph but had lost confidence in the brakes so didn't drive in as deep as I could have. About the third session of the day I did three consecutive hot laps and the brakes dropped off a cliff, coming into an 90* corner pushed the brake pedal to the floor four times an had to yank the hand brake an slide around to keep it on the black stuff. New jocks required.
The rotors are stock and f$&@ed so I'll get some new pads and rotors and when I get the new bar fitted up look at some cooling ducts. Really happy to tuck her in the shed with a bunch of jobs and upside before next season kicks off. Fender flares, (maybe some wheel spacers), front bar with some aero and cooling mods, transplant the cage, new wing stand to get it up higher and maybe paint the mismatched panels and some more seat time amounts other things
IMG_1481440269.888854.thumb.jpg.540e82cc
IMG_1481440287.783409.thumb.jpg.cbf70510
  • Like 2
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
