Hi Guys,
thought I would start this thread here for anyone interested in the white pearl metal flakes and white silver pearl. I am currently doing all body work and painting an R33 Skyline in QM1 Nissan White - Group 2 - COB System (Clear Over Base)
Just thought I would throw this in here for anyone looking at different coatings thickness coverage or color - I will add the high quality photo's tomorrow after the cards are complete with the top clear coats - hopefully the images do the paint justice as we know from real paint to photo is sometimes hard to get an exact representation.
I have cut 30 test spray cards 100mm x 100mm composite sheeting - lightly sanded and primed in 2k primer
15 Test Cards Sprayed in White Base coat
15 Test Cards Sprayed in Black Base coat
To choose the metal flake and pearl coatings for the vehicle - we have used different coatings
White QM1 Base Coat - Cards
White Pearl Metal Flake - 1 coat 2 coats and 3 coats - with 1 coat of White Silver Pearl
White Pearl Metal Flake - 1 coat 2 coats and 3 coats - with 2 coats of White Silver Pearl
White Pearl Metal Flake - 1 coat 2 coats and 3 coats - with 3 coats of White Silver Pearl
White Pearl Metal Flake - 1 coat 2 coats and 3 coats - with 1 coat of Silver Flake and 1 coat of White Silver Pearl
Image Flat - No Pearl or Top Clear Coat
Black Base Coat - with 375 Micron Red DNA
Black Base Coat - with Red Flake - 1 coat 2 coats and 3 coats
Black Base Coat - with Red Flake - 1 coat 2 coats and 3 coats with 1 coat of White Metal Flake
Black Base Coat - with Red Flake - 1 coat 2 coats and 3 coats with 1 coat of white metal flake and White Silver Pearl
Image Flat - No Silver - No Pearl or Top Clear Coat
I have marked the back of the cards with the coatings and will update this tomorrow - from memory I think I put a coat of silver on one or 2 cards
Silver Flake and White Silver Pearl will be painted tomorrow - then the top coat clear.
Flake Coverage with DNA FX HDIC High Definition Intercoat
375 Micron Flake painted with Devilbiss 1.8 SLG
Basecoat, Pearl and Top Clear Coat - Painted with Devilbiss GTI Pro - 1.3mm with TE20 Air cap
If this post helps one person with white or black with the flakes and coatings then it makes it all worth it.
Hi All,
See below images for the sample cards we painted over White QM1 Base Coat and Black Base Coat - some of the white cards with 2 3 and 4 coats were just to throw some extra coats on to see the color change and how it affected the metal flake appearance with excess pearl.
  • As you will see in the images 1 coat white metal flake and 1 coat pearl is almost similar to 2 coats white metal flake and 2 coats pearl.
  • The white pearl metal flake with 1 coat and 1 coat of silver pearl looks great, the 1, 2 and 3 coats of just white pearl metal flake over white looks pretty cool.
  • Obviously the Red Flake over Black looks great.
  • The overload cards just wanted to post them here to show difference.
Make the QM1 White Nissan paint shine a bit better than just plain white.
The only issue is these look better when they are in sunlight direct light when you move them and see the colors moving. Hopefully the quality of the images do some sort or justice. If you want to check the video see below link
https://youtu.be/n7Dft_w_7WA
Edited by tuning_vs_hardware
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
    • Ok...its taking me long enough to finally do this.  Feck financial security...heart disease will get me soon enough anyway So welcome to the garage..."Clem" Belsil80 has been running a 370Z in Super TT series. So after entering with him in last years Winton 300 i figured I  need my own car. Seems SAU Vic race cars need to be yellow....{tick} Reckon with enough motor i will be able to make up for the lack of talent and stay ahead of the 370Z... but the LS powered S13 and E36s are a ways up the road Aim is to have a car that doesnt stop or turn but has a bit of shed built motor with jam...maybe some cream  First step is getting this ex drift car log booked I am keeping faithful silver car. As the road-club car gets upgrades the race car wil get the sloppy seconds
    • Assuming that they will come off without damage at all.... i would have thought just pull straight up off the spindle with a something or other than can reach underneath. Have you searched for youtube vids of people doing similar on R34s or any other Nissan from the same vintage? They should be the same technique, in all likelihhood.
    • Keeping in mind that sandblasting is really aggressive on softer metals like cast alloy, and you can do damage that you might regret. For trash wheels, not a problem. For wheels with value/scarcity issues, etc.... perhaps a less aggressive media is a better choice?
    • Don't get all high and mighty. Experienced spanner wielders know exactly what effort is required to release an Oof.
