pardon my ignorance, but how you open injectors for more than 100% of the time? is it calculating say a 36ms required pulse width when the cycle time is only 30ms, but in reality, the injector has saturated?
It's calculated on time from close to open to close. Over 100% basically means they never close fully
What base pressure are you running ?
Standard 3bar from memory plus a health 30psi bump when it comes on boost haha
Edited by SimonR32
This was a year ago on 13psi and pump gas (and i guess it was 480whp)
https://www.youtube.com/watch?v=st9cO2XkG8A
What kind of bullshit dyno run is that? Couldn't even turn up the volume and the run was over.
  • Like 2
Am I still the only one wondering how a 33 can be complied in the states?
Maybe on paper it says it's a kit car? So car came in all bits and pieces and they legoed the shit out of it and now bares Honda plates?
  • Like 1
They didn't import them they just sailed them over and keep them docked in the harbour when not using them on land.
  • Like 4
Another American guy posted about this recently. I think that the required crash testing was performed a while ago so they can be imported.
In regards to your comments on the other dyno results thread in relation to Z32's in America making 500 wheel horsepower with stock turbos.
that's again about 200hp at the Wheels more then I personally saw on my Z32 and mine had slightly higher flowing turbos from what I was told and it did have bigger intercoolers on both sides as it was a limited Steve Millen limited edition version which had some aftermarket options thrown in and twin 3 inch exhaust straight through and a huge K&N air filter sitting right at the front grill so you could say there was no restriction in front or behind these turbos.
we ran them at 15 & 17psi and apart from more low down response we found virtually no extra power over 13psi.
which was basically where those little T25's are most efficient anyway and anyone who has owned a Z32 knows they can run hot at the best of times so no point pushing the little turbos Beyond the limits for f/a gain.
The 13psi got us 301 AUS hp at the tyres so way off the 500 USA hp!
It's a 15 year old article from autospeed but still up... http://www.autospeed.com/cms/article.html?&title=Stillen-Sizzler&A=1003
Edited by mr skidz
Umm sorry to say but there are already a few Z32's making 300rwkw on stock turbos and not a lot of work done, E85 works wonders along with some other bits that have been developed in the last few years. Friends 300ZX made 300rwkw @ 20psi on a catback, SMIC, Top feed/E85 setup and hits 250rwkw @ 4000rpm. Mine makes a bit more than that with 3" dumps, 2.5" cooler piping and 22PSI. Your one not making power past 13PSI would indicate turbos from the auto model 300ZX with tiny turbine housings.
To be clear what "record" are we talking about? GT2860-5's on their own? On an RB? on any engine?
If dyno dynamics, A member on AUS300ZX made 492.5rwkw @ 28PSI with them. If RB, i'm fairly sure i saw 474rwkw from a 2.8L GTR somewhere on here. If its the Dynojet record then its well north of 750rwhp from what i remember.
Are you 100% sure that z32 result wasn't gtx2860s?
Anyway you seem to be possibly missing his point about using a Japanese car that has been sold in both markets then getting tuned with a stockish setup to compare general dyno numbers
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
