Lifting base pressure 15oddpsi will see more flow for more topend
What C/R is it running
You talking about raising the fuel pressure? Its already at 58psi. Figure another 25psi when under full boost you are looking at 83psi rail pressure.
Not sure on cr
1000cc injectors is way to small for 500kw on e85.....
Or at least a Aussie 500kw that is.
This ^
I made 604hp with my -5s on my Tomei motor at 27psi (still 2.6) on E85 with 1,000cc injectors twin bosch pumps and a Walbro 460 lift pump (to surge tank) and they were almost maxed out
Most GTR-s that run -5s here in Oz make between 450-480kw max on corn syrup
I think dyno read out is a bit too optimistic IMO but we all know how to settle this don't we?
you will need a drag strip
and a go pro
and a pic of 400m..........wait..........I mean quarter mile timeslip
  • Like 3
Not sure on cr
No, I mean 58psi base is already 15odd psi higher then the base we usually see, mine is at 50psi which is already high then normal
You don't know what the compression ratio is ?
What is the smallest id of your exhaust system?
3" I believe.... And its Rickys car, just so there is no confusion.
I did not build the motor so I do not know the specifics.
most modern fuel systems run 58 or so psi. That is where we normally run things. Had this car at 43.5psi in order to help with pump gas drivability but we had to turn it up. The ID1000's are rated at about 1150cc/min at 58psi.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
