1000cc injectors is way to small for 500kw on e85.....
Or at least a Aussie 500kw that is.
this finally someone hit the nail on the head
But we are comparing American pony power vs Australian horse power
Odd..... I have made over 900whp on a 3" exhaust. Even that much must cover our apparent over zealous dynos.
I think low 500 horse power at the wheels on a gtr your pushing shit uphill with a 3 inch exhaust!
how you achieve an extra 400 horsepower Power from the same size exhaust has me wondering if mushrooms are to blame [emoji23]
Sorry, I mean that camaro. I'm interested in what it trapped
Sorry but no. That car was built for speed competition such as standing mile events (see: The Texas Mile). The car did 168mph at the half mile & 203.8mph at the mile marker.
We have another camaro that made a touch over 750whp. Also through a 3" exhaust, it frequents the 1/4 mile often. Best pass to date on a stock short block & stock auto trans is 10.3 @ 137mph @ 4160lb
That car has a similar turbo system as the higher power car, just a much smaller Precision 7175 turbo.
Edited by Jc052685
This is the best result i have seen, this engine is about as built as they get,
2.8 stroker
Naprec/HKS prepped and ported head with OS valves
260 x 10.85 custom cams with very serious springs, forget brand :)
Port matched manifolds attached to Racepace modded -5s
Full maf less hard pipe kit from air box to plenum
Nismo intercooler and Nismo Plenum
ID2000s with twin 044s on a custom surge tank
Ross trigger wheel setup
And twin 3" exhaust
Plus heaps of supporting gear
Just got the OK to post this from the owner ?
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
