How is this possible i cant get more than 405rwkw turbos apparently outa puff ... built motor fair bit of head work although std actuators and inlet. I call bs unless huge intake work
Fuel
Exhaust
Intake mods
Cams
Head work
It can be done, but the right parts need to be employed.
List everything...
Once the turbos are out of flow you can then make more power by using what they flow more effectively/efficiently like comp ratios and cam timing etc
E85 helps here to
but how will the exhaust gases get past the 2x restrictors?
unless you twin externally gate them.... then you might as well just get a single :)
  • Like 1
But don't you get into issues of spinning them too fast with a bang to follow?
Depends on engine size really, 30psi on a 2.8 will make them spin to fast, 2.6 not so much but yeah still getting up there
Also by making the engine run more efficiently means the turbos don't have to work as hard for the same power
I have made 458awkw from GT-RSs on my 3.0 which run the same exhaust as -5s and Piggas has made 473rwkw with -5s on a 2.8 and I have been talking with a dude the has made 716rwhp from -10s on a 2.6 so I guess it comes down to how much power you want to make
you "could" do this.. 3" dump -> Cat (because we are sensible) -> 3.5" Cat Back... plumb gate back into 3.5" cat back.. bypassing the cat :)
legal enough.. at EPA they won't be cracking gates.
What was the cause for yours to hand grenade
Who knows, bearings were perfect, no oil stavation or heat damage apparent. Running 26 psi on a built 26.
Everyone threw their arms in the air, no one's fault and said show me the money for a rebuild. [emoji19]
Going single also can be risky if your not willing to external gate to atmosphere, i know people who plumbed back gate into 3" exhaust and wonder why its a laggy pig.
That's not risky, that's stupidity. Change 3 inch to something that belongs on there. I bet everything improves.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
