My car was stolen a few weeks ago and i finally have it back. It was assesed and classed as a repairable write off.
I have the entire car. Get in quick before parts begin to go.
-Complete Motor and transmission & transfer case, with wiring looms and ecus - $1900 together willing to sell seperate
-Turbo is available - $600
-Standard Dump Pipe and CAT available - $100
-Factory sports exhaust with variable sound controle available - $300
-Black Leather Interior Front seats availabe (heated) - $250
-Rear Diff available (non LSD) - $320
-Aluminium Bonnet available, a few stone chips - $300
-Factory Grey Nissan carpets - $150
-HDi Intercooler - $400
-Black Dash and pop up TV screen available (pm or comment what part you are after)
and more just ask
Parts from the interior have been sold.
-Suspension (Sold)
-Rims and Tyres (Sold)
-Headlights (Sold)
-Aftermarket Exhaust (Sold)
Feel free to PM or message me for a price or what part you are looking for.
0478 816 818
Located Wangaratta
Got the motor out of the car and have reduced the price, nothing wrong with it just doesn't owe me as much.
Chasing $1,000 for the motor and transmission
It is complete motor:
-Engine with Coils, Injectors and everything else
-Wiring Loom, both Engine and Transmission
-ECU's, both Engine and Transmission
-Awd Transmission and Transfer
-Front Drive shaft
-Front Diff
(Turbo not included)
I would rather sell the entire motor as one but might be willing to separate certain parts
Still have a few things available that were not damaged in the crash. See below for pics and prices.
I still have the shell, so if you need something i may be able to help you out
If you are interested let me know and i can see if i can work out a price for freight or arrange a time for picking it up
Aluminium White Bonnet, a few stone chips (see pics) $150
Factory Standard Radiator with thermo fan to suit intercooler $80
Front Glass Fibre Composite Radiator Mount $80
Rear Under Floor Compartment Tray $30
Front Black Heated Leather Seats $200
Glovebox (hinge pin missing) $30
Centre Console (Centre Glove box is Damaged and not included) $50
Drivers Side Air Vent $10
I also have
Factory CAT back Sports exhaust with variable exhaust note control, comes with wiring, switches and electric motor $300
Factory front and rear Suspension with King Springs for AR-X $300
Edited by DrLui
Parts still available
Feel free to PM me an offer
Front Leather Seats - $200 (See Pic Above)
Standard Radiator, with thermo fan to clear intercooler - $80 (See Pic Above)
Rear White Aero Bar, has a few marks - $400 (Pics To Come)
AR-X Suspension, with king springs - $350
HDi Intercooler Kit, only was installed for a few months - $350
Grey Floor Mats - $100
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
