I have a HKS actuator that came with my 2835ProS turbo which I am led to believe is a 1bar actuator. Never tested this theory and have been running this setup for a while until the actuator bar broke. Fixed it and the car still makes its power however boost does not seem to be coming on as hard or holding as well. I ran the actuator only and maxes out at 7psi not 14psi as rated. Tension is all good. I am interested what anyone else with a 1bar actuator is getting or any theories on what may be wrong (possibly internal to the actuator)? Seeing mechanic tuesday.
Thanks
https://www.sau.com.au/forums/topic/46308-hks-actuator-playing-up/
If you didn't get the actuator rod exactly the right length (ie; shorter) you have reduced the preload on the spring. This means the wastegate will open at earlier than previous boost levels. Try lengthening the rod. :D
my hks actuator is 10psi (same as rb20 stock) it holds 10, 15 and 17psi (my 3 boost settings) perfectly with the e-boost. I expected it to be a 1bar actuator but i am happy it is not.
Evan
So I can assume the least boost you can make would be 10psi indicating mine may be faulty. How do you like the e boost?
Maybe I am thinking wrongly that if the rod is shorter it is preloaded making more effort to open when by lengthening it may give me the results. I will try.
To be honest I love the e-boost, boost comes on fast, smooth and holds beautifully.
Also I have it mounted below the steering wheel and to the left, I actually find while giving it a poke that the boost is much easier to read with a big digital readout than an analog one that was near the a-pillar.
Very happy.
Evan
