Removed due to upgrade/replacement. Haven't fully separated/cleaned things up yet. Can take more pics as needed.
Complete hot side, manifolds to muffler including.
- Tomei Expreme Stainless Manifolds - $800
- R34 Stock manifolds - $100
- Stock manifold shields - $20
- R34 BB Turbos with drains and actuators (80ks on these, some shaft play, can take video/open to inspection) - $250
- Tomei stainless dumps (v-spec compatible with EGT port). $600
- 2.5" into 3" front pipe, with flex pipe. $200
- 3" mid pipe with flanged stock Nissan cat and basic mid muffler into 3.5" rear pipe/muffler section with cannon. Can only see a Jasma label on it - SR. - $600
Or take the lot/most as a complete system and make me an offer.
R34 PowerFC LJetro with hand controller (with tune for stock injectors/turbos) $800
R34 Standard fuel pump. $50
R34 AFMs $100
Standard mirrors in KR4, plug removed. $100
Standard Cam Gears. $20
Twin turbo pipe. $100
Rays vinyl wheel stickers, full set. - $30
I can assist with fairly cheap postage or pickup is fine.
Located in Wodonga.
Price drops, buy buy buy.
- Tomei Expreme Stainless Manifolds - $500
- RB26 Stock manifolds - $80
- R34 BB Turbos with drains and actuators (80ks on these, some shaft play, can take video/open to inspection) - $SOLD
- Tomei V1 stainless dumps (v-spec compatible with EGT port). $500
- 2.5" into 3" front pipe, with flex pipe. $180
- 3" mid pipe with flanged stock Nissan cat and basic mid muffler into 3.5" rear pipe/muffler section with cannon. Can only see a Jasma label on it - SR. Came of 34, but will fit 33 with minimal mods - $500
R34 PowerFC LJetro with hand controller (with tune for stock injectors/turbos) $700
HKS EVC6 - $400
R34 AFMs $100
Twin turbo pipe. $80
You know you want to throw me some offers and buy lots of this stuff at once and get a deal.
As much as I want to clear up space in my shed and put some money back in the bank :D
  • 1 month later...
Only stock bits and the cat back and front pipe left now.
R34 AFMs $100
Stuff will go cheap, just want to clear up space.
Also have plenty of S13 stock bits left over also.
Price drop, list update.
R34/RB26
- RB26 Stock manifolds - $60
- Stock manifold shields - $10
- 2.5" into 3" front pipe, with flex pipe. $150
- 3" mid pipe with flanged stock Nissan cat and basic mid muffler into 3.5" rear pipe/muffler section with cannon. Can only see a Jasma label on it - SR. Came of 34, but will fit 33 with minimal mods - $400
R34 AFMs $100
R34 Non Vspec air guides for brakes. $300
R34 GTT Console ilid skin, mint condition. Hinge and leg no good though. $100
S13
- S13 CA18 Viscous Centre and 6 bolt shafts - dunno what these are worth$$
- GKTech V3 S13 to s14 toe arm adapters (use S13 arms in s14 subframe). $Not sure either
- Carpet
- Roof lining,
- Lots of interior plastics
- Interior light
- CA18 Cam Gears
- CA18 Intake Cam
- CA18 AFM and plug.
- a TPS
- Washer fluid bottle and neck
- Standard space saver.
- CA18 carbon canister
- Rear toe arms
- Rear camber arms
- Coil pack cover
- Leaking power steering rack that includes the rack ends (the rack ends might be S15 ones as I used an S15 rack and some bits from the S13 rack ends/tie rods.
Or take a bulk lot for cheaper.
Located in Wodonga.
  • 4 weeks later...
  • 1 month later...
Bump, make some offers, need the shed space :)
34/RB26
R34 AFMs $100
S13
- Carpet
- Roof lining,
- Interior light
- CA18 Cam Gears
- CA18 Intake Cam
- a TPS
- Rear toe arms
- Rear camber arms
