Removed due to upgrade/replacement. Haven't fully separated/cleaned things up yet. Can take more pics as needed.
Complete hot side, manifolds to muffler including.
- Tomei Expreme Stainless Manifolds - $800
- R34 Stock manifolds - $100
- Stock manifold shields - $20
- R34 BB Turbos with drains and actuators (80ks on these, some shaft play, can take video/open to inspection) - $250
- Tomei stainless dumps (v-spec compatible with EGT port). $600
- 2.5" into 3" front pipe, with flex pipe. $200
- 3" mid pipe with flanged stock Nissan cat and basic mid muffler into 3.5" rear pipe/muffler section with cannon. Can only see a Jasma label on it - SR. - $600
Or take the lot/most as a complete system and make me an offer.
R34 PowerFC LJetro with hand controller (with tune for stock injectors/turbos) $800
R34 Standard fuel pump. $50
R34 AFMs $100
Standard mirrors in KR4, plug removed. $100
Standard Cam Gears. $20
Twin turbo pipe. $100
Rays vinyl wheel stickers, full set. - $30
I can assist with fairly cheap postage or pickup is fine.
Located in Wodonga.
Price drops, buy buy buy.
- Tomei Expreme Stainless Manifolds - $500
- RB26 Stock manifolds - $80
- R34 BB Turbos with drains and actuators (80ks on these, some shaft play, can take video/open to inspection) - $SOLD
- Tomei V1 stainless dumps (v-spec compatible with EGT port). $500
- 2.5" into 3" front pipe, with flex pipe. $180
- 3" mid pipe with flanged stock Nissan cat and basic mid muffler into 3.5" rear pipe/muffler section with cannon. Can only see a Jasma label on it - SR. Came of 34, but will fit 33 with minimal mods - $500
R34 PowerFC LJetro with hand controller (with tune for stock injectors/turbos) $700
HKS EVC6 - $400
R34 AFMs $100
Twin turbo pipe. $80
You know you want to throw me some offers and buy lots of this stuff at once and get a deal.
As much as I want to clear up space in my shed and put some money back in the bank :D
  • 1 month later...
Only stock bits and the cat back and front pipe left now.
R34 AFMs $100
Stuff will go cheap, just want to clear up space.
Also have plenty of S13 stock bits left over also.
Price drop, list update.
R34/RB26
- RB26 Stock manifolds - $60
- Stock manifold shields - $10
- 2.5" into 3" front pipe, with flex pipe. $150
- 3" mid pipe with flanged stock Nissan cat and basic mid muffler into 3.5" rear pipe/muffler section with cannon. Can only see a Jasma label on it - SR. Came of 34, but will fit 33 with minimal mods - $400
R34 AFMs $100
R34 Non Vspec air guides for brakes. $300
R34 GTT Console ilid skin, mint condition. Hinge and leg no good though. $100
S13
- S13 CA18 Viscous Centre and 6 bolt shafts - dunno what these are worth$$
- GKTech V3 S13 to s14 toe arm adapters (use S13 arms in s14 subframe). $Not sure either
- Carpet
- Roof lining,
- Lots of interior plastics
- Interior light
- CA18 Cam Gears
- CA18 Intake Cam
- CA18 AFM and plug.
- a TPS
- Washer fluid bottle and neck
- Standard space saver.
- CA18 carbon canister
- Rear toe arms
- Rear camber arms
- Coil pack cover
- Leaking power steering rack that includes the rack ends (the rack ends might be S15 ones as I used an S15 rack and some bits from the S13 rack ends/tie rods.
Or take a bulk lot for cheaper.
Located in Wodonga.
  • 4 weeks later...
  • 1 month later...
Bump, make some offers, need the shed space :)
34/RB26
R34 AFMs $100
S13
- Carpet
- Roof lining,
- Interior light
- CA18 Cam Gears
- CA18 Intake Cam
- a TPS
- Rear toe arms
- Rear camber arms
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
