Greddy air divider, plus i forgot to update this with new prices as i just want this stuff out of here.
R34 GTR/GTT/RB26 -
Greddy air diversion panel - $80
2x Stock manifold shield sets - $10
2.75" mid pipe with flanged stock Nissan cat and basic mid muffler into 3.5" rear pipe/muffler section with cannon. Can only see a Jasma label on it - SR. Came of 34, but will fit 33 with minimal mods - $150
R34 Standard fuel pump. $40
Standard Cam Gears. $10
R34 Non Vspec air guides for brakes. $100
R34 Console lid skin, mint condition. $50
Universaly catch can, properly baffled with sump drain, was $200 new, No hoses $140
S13 - Free/6pack/whatever
S13 CA18 Viscous Centre and 6 bolt shafts and diff cover.
S15 crown wheel.
Carpet
Roof lining
Interior light
CA18 Cam Gears
CA18 Intake Cam
S13 Subframe, bushed tired but no cracks.
TPS
Washer fluid bottle and neck
Standard space saver.
CA18 carbon canister
Rear toe arms
Rear camber arms
Traction rods
S13 and S14/15 RLCAs.
S13 Castor arms
S13 and S15 Tie rod ends.
  • 9 months later...
    • I can't believe that anyone is foolish enough to believe that the base maps are for any other purpose than to drive the car up onto the trailer/truck or gently creep it to the dyno. No matter how good they are, they can never be any better than the factory maps**, and only the foolish trust those on a significantly modified setup. **Yeah, yeah. I know there's also the difference between factory maps being fixed to certain injector sizes and MAP/AFM/VE relationships, and the likely aftermarket ECU base maps being better able to handle the sorts of changes that would render a stock ECU dangerous, like different sized injectors. But let's just ignore that for the moment, because the principle is still the same.
    • I'm shocked, you've owned a Skyline since 2006 and never joined SAU before now! 😮   Welcome, it's much quieter these days than it was in 2006, but lots of very knowledgeable ones lurk around here. I actually think in outage we've forgotten more about Skylines than anyone knows about them today... 😛
    • So it could give us some info. Such as we find out what number they started at, and we know how many of those blocks came before it.
    • Everyone wants an ECU they can plug onto their engine, modified or not, and put of the box it just runs perfectly like a brand new modern engine straight off the production line. Too many people just don't understand things like the base maps are as you said, just to give a starting point, and then you need to spend time getting it right for your vehicle.   I wonder if the people wanting it are the same ones who'll just buy a chip for a "stage 2 tune" online and then wonder why their engine blew up...
    • Quite possible! And well worth checking out, as it will be more durable than paint
