ummm no i dont have pics atm, but i can get em!! it's alot of work though.. i describe it to you!
series 1 GTST --
where the hazard light switch and demister switch were i have an air/fuel ratio and water temp guage! both are the smaller autometer guages
then on the other side where the mirror switch is there is a boost guage! larger style autometer!
then all switches have been moved to the center console!
I might just put it back on the base of my A-pillar. It really is the best spot for it. I'll get defected for my exhaust before I get defected for my boost gauge anyway...
The gauge I have in my dash already is completely blocked by the windscreen wiper stalk. I have no idea why it was positioned where it is. :confused:
i'll get photo's of mine tomorrow, and post em up. i only use my boost guage if i suspect something might be happening with the feel of the cars acceleration.. not something that i constantly look at!!
on the pillar is just easy to spot when driving past etc!!!
if you have them in a pod, they are less likely to pick it up unless they go over your car.. but if you have cups and open guages they see em when you drive past etc... been done twice when i had some on the pillar! (granted it was a monsta tacho and boost- but it looked good)
I've got mine on the A-Pillar, but if a cop ever tried to defect me for it I'd get pissed off, cause the way I see it, taxis with their souvalaki ordering system thingy are just the same! But the government has different laws for different things I suppose... funny how the law works against you!
sorry for the large image but i cant be assed downloading the file and reupping it to my webspace.
i have mine located on the steering column, passed registration fine.
front view
side view
hey where did u buy that gauge holder from and how much...thats the best idea ive seen so far ....
it came with the car when i imported it so I have no idea unfortunately.
its a piece of carbon fibre shaped/cutout around the top of the gauge, its quite a tight fit and it holds it in there very well. the fibre is then simply screwed to the steering column with some 90 degree angled pieces of metal.
The gauge itself sits in a small cup.
its quite simple and does the job perfectly and is in perfect view without blocking any dash gauges at all.
Shaun
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
