give or take a few years, you'll end up doing it LOL
more power, more torque, more response, more cheaper, less heat issues, less piping, less hoses to fail, less shuffle, less blown rear turbo
hahaha
  • Like 1
So I bit the bullet and had the motor removed to do all the heater hoses along with anything else that popped up.
Plenty more nasty little surprises but at least its getting sorted and will help me sleep better now.
Here's some progress pics.....all new genuine Nissan hoses.
So motors all back in now and running well.
While it was out I had the plenum painted wrinkle black to match everything else once I get round to it.
Have just had some new Hankook Rs-3 tyres fitted and I'm off to get a wheel alignment this arvo and that should be it ready for this weekends hillclimb.
Nothing feels better than KNOWING that everything is right. All the little things are taken care of. Then you can have the spirited drives with out that little niggle at the back of your mind.
Just a note if you already haven't replaced them are the two plastic connectors on the firewall. One at the back of the plenum which just connects two water hoses and the other behind the cam cover for the heater hose junction. They are prone to fall apart from the inside and flick plastic pieces into your coolant system. Well worth replacing if you haven't already.
  • Like 1
A few pics from the weekends hill climb (I believe it is the fastest speed hill climb in Australia)
I think I was the slowest in my class but I had a ball and managed to drive there and home so can't complain about that. (Unfortunately some weren't so lucky :()
Time for some more suspension work ready for the next one in August.
ye there's vids on youtube, search 'R32 GTR crash mt alma 2016'
Never like to see that happen obviously but this guy especially was a top bloke, was really cut up afterwards obviously.
Another GTR (32) and a few evo's had some pretty big offs too :-/
ye Glyn, I think it was a case of just too much speed, I chatted to him afterwards but didn't go into the details, doesn't look too fast but I believe he was somewhere around 170-180kph around there :-/
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
