  • 1 month later...
Not too much in the way of updates as I've been working remote a bit lately.
Have had the driveshaft's overhauled and had it back on the dyno chasing more midrange which was successful.
Now just trying to enjoy her for the moment, a few pics from the weekend taken by a mate.
  • Like 3
  • 2 months later...
Added another car to the stable...a Sil80.
Will use this for doing the things I'm now too soft to do in the GTR :blush:
Needs a bit of work but couldn't knock it back for the $$$ already has blacktop SR20, R32 GTR brakes (5 stud) etc...
  • Like 3
  On 23/06/2016 at 6:02 AM, mr_rbman said:
5 - Removed my front Bilstiens as one had begun to leak and have sent them off to Quadrant suspensions in Victoria for a rebuild (significantly cheaper than anyone here in Adelaide :()
Expand
Just out of interest what is the model number of the Bilsteins and how long is the shock body?
  • 3 weeks later...
Expand
I'll suss it out for you next time they're out the car.
have just entered a tarmac rally event and may pull them out prior time pending....
  • 3 weeks later...
  • 1 month later...
Picked up some Enkei RPF01's in exact same sizes as my Rays Impul RSII's (18 x 9.5" +15 all round), bit of an impulse buy.
Love my other rims in the flesh but black on grey doesn't look the best in photos, Love the gold enkei's in photos but unsure about them in the flesh, mmmmmm.
Put my other rims up for sale but probably won't be too disappointed if they don't sell.
  • Like 1
  On 23/01/2017 at 1:16 PM, okooko said:
ive got the same in matte black - those are the best straight up fit for the r32
love the offsetting colors
what rubber you got on those?
Expand
They came with some plain almost brand new Achilles ATR sports but I'm trying to move them on and have ordered some Nankang NS-2R semi slicks, the reviews they get seem to be hard to go past for a weekend warrior which sees the odd hillclimb for <$150 a corner.
  On 23/01/2017 at 11:08 PM, GH05T said:
LOVE THE WHEELS MAN, SUCH A GOOD SIMPLE DESIGN WHICH FITS THE 32
AAAAAAAAAAAAAAAAAH sorry caps :P
Expand
Cheers Glyn, a few gunmetal grey 32 GTR's getting round Adelaide at the moment, think we need to have just a gunmetal meet up soon :1_grinning:
  • Like 1
  • 3 weeks later...
    • ...just a note of warning, you shouldn't drive it about with the TCU in limp mode with only 3rd gear available ~ apart from the fact you end up sheering the ATF at the torque converter interface, the high clutch in these isn't especially the strongest, particularly bolted to the RB25DE mill...which is likely a 4AX01 box with lighter duty high clutch (the RB25DET got the bigger high clutch)...be careful out there...
    • Hoping to do similar mods to my RB20 once I get it running and reliable again
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
