On 2/10/2019 at 11:51 AM, mr_rbman said:
ABS is one things that isn't back in yet, have heard bleeding that is a nightmare so not looking forward to it...
My motor was rebuilt by the previous owner where they just cut the a/c lines and basically ruined the whole system, i'm in the process now of trying to chase bits and pieces down in order to try and have a/c running when the car is back together...
Don't get caught releasing that stuff to atmosphere, not good...
My car should be done with the panel beaters this week, so will share some pics. I actually called a number of people to come and collect the gas, as 2 of them that came out, said they don't have the right machine, apparently its too hard due to the age of the car.. wtf. Anyway so that took me a while but all done.
Removing the AC system was actually very easy once the gas was removed. I chose to go with the original matt black color. Will de-grease all the parts and fit new sleeves to all the looms where possible.
I left the ABS and brake assembly on as kinda needed it haha. The workshop will do all of that for me, and I'll just have to somehow bleed the fker.
Any progress on yours so far?
  • Like 1
Sloooooow but steady progress nevertheless...
Just waiting on bearings to come in now, as you can see mine were put together by a Muppet in a sandpit by the looks of things :34_rolling_eyes: then the assembly of the motor will take place...
Finally got the block back earlier this week from being sleeved and machined, took the opportunity to have the crank cleaned and grub screwed at the same time... always wanted to have a freshly cleaned and painted block, came out pretty good i think...
At least in hindsight i now know every little inch of what's now gone into this motor so hopefully it will help me sleep that little bit better at night...
  • Like 4
5 hours ago, WantGTR said:
Wow. Those twins look serious. What are the specs?
Basically -7's with some larger billet wheels...
Time will tell I guess the results...
My hope is for -9 response with a touch more top end but who knows...
Just now, r32-25t said:
I keep seeing these pop up in the -5 version but no one seems to be forthcoming with actual results
ye i think everyone is in the same position as me with their builds...
I too know a heap of people who've gone for the '-5 versions' but i seem to been one of very few gone for the smaller versions...
  • Like 1
2 minutes ago, r32-25t said:
Yeah I have vcam and also intend on building a 2.8 when it lets go
she'll be right then, i'll be keeping a keen close eye on your build ;)
glad to see as good as these new big singles are these days there's still a few of us running twins.....:91_thumbsup:
  • Like 1
48 minutes ago, r32-25t said:
I’ll admit right now I’m on the fence about which way I’m going and if I don’t see results for them soon they may get over looked
Are you looking at the MMP ones?!
56 minutes ago, r32-25t said:
Yeah they are one option I’m looking at
Fantastic to deal with to begin with and very knowledgeable. BUT...
Once I paid the money the customer service was dismal to say the least...
I paid for mine in October and didn't get them until January (when i was told they were 'on the shelf') and then when they did arrive they came with no actuators which i then waited another month for...
Even if the results are fantastic I think i'll always have a sour taste left in my mouth unfortunately from my dealings with them....
Just my 2c anyway...
Edited by mr_rbman
mistake
  • Thanks 1
  • 3 weeks later...
  • 4 weeks later...
2 hours ago, jmknights93 said:
Really digging the rocker cover colour. Looks mint!
ye i'm convinced now it's all come together thankfully...
got a bit of a mix in the engine bay of gunmetal grey, black and wrinkle black... will have to see how it all looks once fully complete...
  • Like 1
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
